Cascadia DD16 getting hot, found solution
Discussion in 'Freightliner Forum' started by uncleal13, Jun 3, 2017.
  1. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    My 2016 Cascadia is only a year old now. The last few weeks it's been running hotter than usual and the fan was kicking in lots. It never overheated but it got close a few times.
    The DD16 has a two stage thermostat, so I thought maybe it wasn't fully opening, so I bought a new one for almost $200. But first a co-worker suggested that the rad maybe plugged seeing as we load in a lot of dusty conditions.
    So this morning I moved the a/c rad and charge air cooler out, and presto here's what I found.
    KB3MMX Thanks this.
  3. AModelCat
    164,628
    That'll do it every time. If it was winter at least you wouldn't need a winter front :p
  4. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    will do it everytime just put a nice wash on it and should be all good to go
    KB3MMX Thanks this.
  5. Cat sdp
    Cat sdp . .
    21,299
    76,154
    Apr 8, 2012
    Orion's Belt
    I always take a garden hose and spray from the backside of the radiator towards the front. Don't know if it helps, but makes me feel better.
    KB3MMX, mhyn and uncleal13 Thank this.
  6. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    garden hose with fireman's nozzle and spraying from backside. it's good to be presoaked by lemon/orange acid containing cleaners for bugs and flys
    uncleal13 Thanks this.
  7. RocketyMan
    RocketyMan Medium Load Member
    549
    337
    Jun 5, 2015
    Garden hose or washing the backside of the rad only helps partly. What you REALLY need is something that cleans the grime actually off the fins.
    There's this stuff you can find at the hardware store that I have GREAT success with. It's made for HVAC condensers, but a radiator for the engine is the same thing!
    Check it out and let me know what you think!
    AC-Safe Air Conditioner Foaming Coil Cleaner-AC-921 - The Home Depot
  8. uncleal13
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Yes I used a foaming rad bug cleaner about three times. Seemed to do the job.
  9. RocketyMan
    549
    337
    Jun 5, 2015
    Nice! Do you have an "after" picture showing what the cleaning did?
  10. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    Just an FYI... next time use plain dry compressed air. Water will sometimes harden the dust into a concrete consistency, making it even more difficult to remove.
    Roberts450 and uncleal13 Thank this.
  11. uncleal13
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    No, but it looked like clean aluminium. Besides the garden hose I also used a booster that uses both the garden hose and compressed air at 120 psi to do the final cleaning.
    Similar to this one.
