Cascadia hard start after PM
Discussion in 'Freightliner Forum' started by PermanentTourist, Nov 27, 2017.
  1. PermanentTourist
    PermanentTourist Heavy Load Member
    749
    881
    Nov 9, 2016
    48 states + Canada
    Hi guys
    So I had a PM done at the Glade Springs VA Petro, and they really fouled it up. Overfilled the oil, got oil all over the engine, etc. Went to another TA and had them redo the oil, but ever since that I am having hard starting issues. Seems that the fuel system is not staying primed. Every time I shut off the truck for a while, I have to pump the little pump next to the fuel filters, otherwise it has a real hard time starting.
    Is there anything obvious or easily solvable that the clowns at Petro might have messed up? I checked the tightness of the fuel filters, they seem to be fine. The big transparent fuel filter holds fuel overnight, it doesn't drain back into the tanks, but when it's running there are bubbles coming up from the bottom. Don't know if it's normal, never paid close attention to that filter before.
    Thanks for any help, and avoid that glade springs Petro, at least on thanksgiving when they're understaffed.
  3. razor1983
    razor1983 Medium Load Member
    500
    509
    Jan 17, 2011
    The bubbles are normal, check the fuel filter o-rings
    06driver and PermanentTourist Thank this.
  4. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    They could've put the wrong fuel filter in there, or not put the O-ring on correctly under the clear plastic cover and your engine is losing prime.
    PermanentTourist Thanks this.
  5. Rjd2018
    Rjd2018 Bobtail Member
    Jul 31, 2017
    Cracked fuel filter cap the small one , overtightened , and check other 2 fuel filter covers for small cracks sometimes hard to see , had this issue before
    Oldironfan Thanks this.
  6. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    You fuel bowl is more than likely sucking air. Go back to Petro or TA, and tell them to fix their problem.
