Cascadia pulls to the right
Discussion in 'Freightliner Forum' started by shim2000, Feb 12, 2018.
  1. shim2000
    shim2000 Bobtail Member
    24
    Got a 2017 Cascadia with 163k miles.....Steer tires aren't towed in or out but it pulls to the right at 15/35/55 MPH, when you use the brakes it goes straight and tire pressure is up to specs..... any ideas what the issue may be???
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    If it pulls to right or any thing but straight, get it to a front end shop or dealership. You cannot have a truck going wild for whatever reason.
    This assumes beautiful blacktop highway. Not the usual ruts etc.
  4. pilewrench
    pilewrench Bobtail Member
    10
    Oct 26, 2016
    I find Freighliner Cascadias with the rear thrust angle out from the factory all the time. Also, sounds strange, but make sure you don't have a tire that is a different size on the truck. It happens. All else fails, swap the steer tires side to side and see if the tire pull either goes away or changes direction. Of course, these issues usually happen with newer tires.
  5. Brandt
    Brandt Road Train Member
    4,624
    6,358
    Sep 17, 2012
