Cat 2ws issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by WREN, May 1, 2021.
  1. WREN
    WREN Medium Load Member
    378
    239
    Jul 17, 2017
    Florida panhandle
    Ok guys, I'm a little perplexed. This 2ws was rebuilt around 100 to 150k miles ago. It has sat mostly since February and didn't get driven much before that.
    The issue is it has a slight shudder/vibration like it has an injector issue. I picked it up Tuesday and put 2500 miles on it and even put some Lucas injector cleaner through it to see if it would clear up but it didn't.
    The part that has me perplexed is its not that bad until 5th and 6tth gear in the 1200 to 1400 rpm. 5th gear shakes the entire truck and vibrates the dash, teeth, sack, and every thing else. 6th isn't as bad and then slight again after 6th.
    It's also worse under a load.
    I'm thinking that because of switching from high end of low range to low end of high its dumping more fuel causing it to be worse?
    I havent checked the fuel filters yet, but they aren't cat. I drained the water separator and it seemed fine. I'm going to talk to talk to the old cat mechanic where I park at but I'm just curious at this point.
    Also, slight blow by but not bad.
    Guesses?
  3. WREN
    378
    239
    Jul 17, 2017
    Florida panhandle
    Also, oil pressure is 65 ish under power and temp stays 190 ish
  4. AModelCat
    164,343
    Sure its not driveline related?
    Had a bad u-joint once. Felt like someone was kicking my seat but only in a narrow range of about 4 or 5 mph. Above or below that speed it was hardly noticeable.
    black_dog106 and Bean Jr. Thank this.
  5. WREN
    378
    239
    Jul 17, 2017
    Florida panhandle
    No I'm not. I just got home about an hour ago. I'm going to check it thoroughly tomorrow.
  6. Arctic_fox
    4,499
    25,377
    Sep 16, 2016
    Had a simular issue with a C15 a few years back. Turned out to be a bad U-Joint that would make it feel like i was a rock in a paint shaker at around 42MPH to 51 MPH. Ended up deforming the drive shaft a bit because the owner made me drive it like that for 3 weeks.
  7. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    That's my reaction too. Driveline issue.
  8. LameMule
    LameMule Road Train Member
    1,148
    7,418
    Jan 19, 2020
    Montana
    Throw it in neutral when you get in 5th and see if the vibration persists at idle.
    WREN and Bean Jr. Thank this.
  9. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Sounds like drive line. U JOINTS OR RIDE HIGHT
  10. WREN
    378
    239
    Jul 17, 2017
    Florida panhandle
    Well, the ujoints are fine but it sure looks awful wet all the way down that side the puke tube is on.
    Bean Jr. Thanks this.
  11. LameMule
    1,148
    7,418
    Jan 19, 2020
    Montana
    How's it feel if you hold it at 1,800rpm in neutral?
    "Well, the ujoints are fine but it sure looks awful wet all the way down that side the puke tube is on."
    Are you talking about the crankcase vent? Blowby?
