Cat 3406B Air Compressor
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TRUCKTHUG, Aug 9, 2011.
  1. TRUCKTHUG
    TRUCKTHUG Bobtail Member
    Abq,NM
    How hard is it to swap out the compressor on this engine? (Cat 3406B) I am not a certified mechanic, but I can spin a wrench. I know that I will need to drain the coolant in the engine, but are there any big mysteries or special tools needed? I would usually just pay a mechanic, but times are tight and I have been quoted prices from $650 to over $1,000 for this job. Any insight or advice will be greatly appreciated! Also, since it looks like I will be doing more engine work myself, does anyone out there know how to get a 3406B service manual bargain.
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    real easy three nuts and a few airlines and off it comes you will have to take the drive gear off and put it on the new air comp a good 1/2 drive impact can do that. oh yea dont forget to drain the antifreeze. one more thing if there is any age on the water lines and oil line replace with new dont reuse the old ones. they get brittle with age.
  4. dave26027
    dave26027 Road Train Member
    1,284
    804
    Sep 10, 2009
    Dallas, Texas
    I did it years ago- if I remember right, instead of draining the coolant, I took off the radiator cap and pinched off the coolant lines to the compressor head with vice grip pliers. (Got to be careful you don't split the hoses.) And, I remember using red hi-temp silicone instead of the stock gasket.
    Here's a tip if you can use it- compressors are rated by flow. I've always installed the highest flow units possible. To me, it's worth it- my last truck was an FLD with a Detroit- installed a 1,200 cfm unit in that truck and was very satisfied with it. Under a load (with manifold boost), it would build pressure and exhaust in three seconds. And it handled every air leak these old rusted trailers had.
    Some drivers claimed large volume compressors use more fuel- but there is no difference in fuel mileage, just more air faster.
    Anyway, always do it yourself, take your time, do it carefully- and you'll probably only need to do it once.
  5. Superhauler
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    yea i did that once 1 day later sitting along side the road calling myself a dumb ###. sometimes it works sometimes it dont.:biggrin_25513:
    dave26027 Thanks this.
  6. puncher
    puncher Medium Load Member
    540
    358
    Feb 12, 2010
    Tn.
    When draining the coolant if you have a water filter put a five gallon bucket under it usually you can hook the handle of the bucket over the bracket then unscrew the filter, when it drains dry then it's down below the water level of the compressor, and save having to crawl under the truck and draining the entire 15 gallons. Sometimes when going back with the new one it won't line up with the gears, just turn the compressor gear a little with your hand. If you want you can also label each line with masking tape and a pen.
  7. TRUCKTHUG
    Abq,NM
    Thanks a lot for the tips. Gonna give it a try.
