Cat 3406C Mechanical Question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Idaho MTN Driver, Jul 3, 2024.
  1. Idaho MTN Driver
    Idaho MTN Driver Bobtail Member
    40
    79
    Jan 22, 2020
    I have a Cat 3406C mechanical engine in a 1997 T800. The truck originally came with a 3406E. I didn't do the swap but it looks to be very well done.
    At idle the dash gauge shows 40 PSI oil pressure and around 60 PSI oil pressure when running down the road. However, there are a group of factory idiot lights in the headliner and a "Low Oil" light randomly flashes on and off when driving. My questions is:
    Is this light simply a "Low Oil" light that isn't working (The truck uses no oil and is regularly checked), or actually a low oil pressure warning light? Could this be something that wasn't addressed during the engine swap and doesn't work correctly because truck was originally powered by a 3406E and not the mechanical engine.
  3. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,956
    Oct 31, 2023
    Install a manual analog gauge so you can see what's really happening.
    W923 Thanks this.
  4. Idaho MTN Driver
    40
    79
    Jan 22, 2020
    There is an analog gauge in the dash for oil pressure. Shows 40 PSI at idle and 60 PSI running down the road. Is that what you are talking about?
  5. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    If it blinks on/off 100 of time while running, then Yes, Its cause the idiot light cluster isnt getting an oil pressure, just turn that light off/remove that bulb, it MAY be possible to trace that wire and add an oil press sensor that reads directly, but pretty sure that cluster takes its info from an ecm... which you dont have... a conundrum for sure
    W923 and Idaho MTN Driver Thank this.
  6. wore out
    wore out Numbered Classic
    17,297
    214,483
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The oil pressure sensor on the C is down by the oil cooler if it has one. Most did not. I would trust your gauge. Look for the extra wires in the truck harness most likely the one for idiot light is grounding out on something (usually right on connector) when it grounds out that turns light and beeper on. Course you can hook a low oil pressure up to the light and buzzer to alert you if you’re in bunk or just zoned out and not hawk eyeing the gauges. Idiot lights and buzzer do not need ECM info to function. My 91 Pete is full mechanical but will beep if it’s low of water, around 225 or so on temp and below 18 psi on oil pressure.
    W923, beastr123, BoxCarKidd and 2 others Thank this.
