Cat 3406e ecm problem parameters
Discussion in 'Ask An Owner Operator' started by Rubberens, Apr 1, 2022.
  1. Rubberens
    Rubberens Bobtail Member
    45
    Dec 6, 2017
    Have a 95 kenworth t600 3406e cat, problem is i got ecm rebuilt and reflashed from go ecm out of dallas tx, but the parameters seem off to me and truck runs slow esp up hill ,from having the truck 9 yrs i couldve sworn it said on the door before the numbers faded it was at 475hp
    the repairman set it to 432hp only.. any one know the right parameters to get it reflashed as i plan on sending it back due to free lifetime warrenty
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    You should kick whoever loaded that 435 file into it in the balls. You need Cat or a Cat Authorized dealer to flash you a good file. If you look on your oil cooler you’ll find a decal with the Max HP that Arrangement number allows for. If it was delivered as a 475 it’s probably good to 550hp, but like I said that decal on the oil cooler will tell you.
  4. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    You don't want a Cat authorized dealer low Nox file.
    black_dog106, Stay Puft and 062 Thank this.
  5. lynchy
    lynchy Light Load Member
    208
    1,085
    Oct 18, 2010
    off the grid
    kt3406e@gmail.com,guy has Utube channel,knows all there is to know bout these engines
