Cat 7FB Fuel Filter numbers
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Jan 21, 2024.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,415
    1,738
    Dec 4, 2019
    IMG_4941.png IMG_4940.png I’ve gotta go pick up a truck and when I get there I want to put new filters on it. 7FB engine and it appears that the filter/water separator, might be a cartridge element? If not correct me and could you give me the part numbers for these? The filter may be a 1R0749(Cat) but not sure on the other.
  3. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    Should be a screen in the bottom pic. Break the 15/16 hex on top loose, then spin off like a normal filter.
    I clean the screen with brake cleaner. There’s a spring and washer in the bottom.
    PSM379, Jordonh, Oxbow and 1 other person Thank this.
  4. PSM379
    PSM379 Heavy Load Member
    946
    3,901
    Apr 19, 2019
    That primary is like stated a screen that you can clean. Secondary is 1R0749
    Oxbow Thanks this.
  5. mile marker 27
    1,415
    1,738
    Dec 4, 2019
    In this circumstance, can the primary be changed to a, “spin on” separator filter by changing the filter head? Did they or do they offer a modification to change this filter head to a spin on style?
    Oxbow Thanks this.
  6. howard7
    howard7 Bobtail Member
    10
    10
    Sep 15, 2022
    Cat has a primary filter base 280-2698 that you should be able to use, might require different fittings for the hoses. Then use primary filter 256-8753
    mile marker 27, Oxbow and PSM379 Thank this.
