Cat Acert Pyro Temps?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dustinbrock, Mar 30, 2017.
  1. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    Just put a Pyro on mine and am going to get my trailers. What are you guys seeing for normal exhaust temp? Which model Cat? Where is your sensor located?
  3. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    MXS acert, post turbo. Highest I've seen my exhaust temp go to is around 1,000 on a hard pull. I am running a tune on mine so I do scan that gauge a lot.
    Running down the road it ranges from 600-900 degrees.
    When I get in some hills I do downshift a gear to rev up the rpm's, helps keep the exhaust temps down, even though the engine will pull it in the high gear.
  4. Steve62
    Steve62 Light Load Member
    170
    98
    Mar 5, 2015
    Northern BC
    Highest I have seen is a little over 800 2006 acert c15 cat 550 hp I pull 140,000 lbs through the mountains
  5. Oxbow
    Oxbow Road Train Member
    13,645
    141,400
    Nov 24, 2015
    950* to 1000* is the highest, but I start backing out a bit @ 950. May be apples to oranges though as I have B model mechanicals. Post turbo, and at elevations up to 10,000 ft. which I find has as much or more to do with exhaust temperatures than ambient temperature.
  6. SAR
    2,756
    36,654
    Nov 26, 2011
    ND
    How's your pyro temps running? I was watching mine today with a load on going down a flat highway at 65 mph with a constant 20 turbo boost, it was hanging at 750. This is on a MXS.
    Oxbow Thanks this.
  7. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,488
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    You do realize that acerts lose close to 500* between pre and post turbo readings?
    Oxbow Thanks this.
  8. SAR
    2,756
    36,654
    Nov 26, 2011
    ND
    I know the exhaust would be running hotter pre turbo, I just didn't realize it was that much. Are the two turbos cooling more of the gasses before it hits the probe post turbo versus a single turbo engine? Is mine running too hot?
    Reason for edit: more info
    Oxbow Thanks this.
  9. SmokinCAT
    1,773
    1,488
    Oct 20, 2010
    It may be closer to 400, I was thinking a friend of mine was seeing close to 500 drop between before and after.
    There is more drop because of the two turbos, a single turbo engine may only see between 200-300 drop.
    I myself would not want to see 1000 post turbo very often especially for an extended period of time.
    Oxbow and SAR Thank this.
  10. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Twin turbos you're most likely loosing 500+ degrees from the turbos and acert motors have steel pistons so prolonged temps of 1500+ in the cylinder head are normal.
    SAR Thanks this.
  11. SmokinCAT
    1,773
    1,488
    Oct 20, 2010
    No that is not normal, a factory 625 doesn't get much over 1300 in the manifold.
    SAR Thanks this.
