Cat c 15 fuel filter question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Don2WS, Mar 30, 2016.
  1. Don2WS
    Don2WS Medium Load Member
    306
    26
    Feb 26, 2010
    Sturtevant WI
    Hello I would like to ask to be enlightened on the fuel filter system on a cat c15 sdp.
    Cat mechanic was telling me that the primary fuel filter needs to be changed every 5k miles to protect emissions components and secondary every 15k.
    He went to say that truck idling the fuel is filtered through the secondary and once truck is running it's filtered through the primary. This makes no sense to me and he couldn't really explain his reasoning
  3. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    the fuel runs though both filters all the time your mechanic is nuts
    BoxCarKidd and Duckman1005 Thank this.
  4. Cat sdp
    Cat sdp . .
    21,297
    76,132
    Apr 8, 2012
    Orion's Belt
    Your guy is 1/2 right....
    The art head fuel supply is taken between the 2 fuel filters... So any fuel going to the art head has only been thru the primary filter.....
    This is why you have to change that filter so often . To try to keep the art head alive..... Good luck
    Also the little screen filter over by the art head should be changed every 6 months or so.
    All the fuel that goes into the engine goes thru both filters..
    rollin coal Thanks this.
  5. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I guess those sdp cats are kinda special.
    Cat sdp Thanks this.
  6. Cat sdp
    Cat sdp . .
    21,297
    76,132
    Apr 8, 2012
    Orion's Belt
    We are special ....:)
  7. Don2WS
    306
    26
    Feb 26, 2010
    Sturtevant WI
    Thank you very much that makes perfect sense. Do you know what the fuel pressure spec is on these sdp?
  8. Cat sdp
    Cat sdp . .
    21,297
    76,132
    Apr 8, 2012
    Orion's Belt
    No.... But I'll find out.
    Might take a day or 2
  9. Don2WS
    306
    26
    Feb 26, 2010
    Sturtevant WI
    Thank I would really appreciate it. Driver had to take the truck to the cat dealer because it lost power. The mechanic checked pressure and it was supposedly
  10. Don2WS
    306
    26
    Feb 26, 2010
    Sturtevant WI
    220 psi and according to him it's needs to be in the low 300s. They changed the pump and both filters and truck is running good again. I'm familiar with the earlier acerts and 3406e and when I messed with the pump I knew 110 was the max or else I was risking the injector orings starting to leak from the added pressure
  11. Cat sdp
    Cat sdp . .
    21,297
    76,132
    Apr 8, 2012
    Orion's Belt
    That's kinda correct ...
    Fuel Transfer pump is like 90 psi..... However the art head gets fuel at 300 psi... The fuel goes thru a couple of solenoids ( not sure of the proper name) and they bump the fuel psi up...
    I'm guessing this thing threw an emissions fit...?
