cat c-15
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Mr Dave, May 9, 2016.
  1. Mr Dave
    Mr Dave Light Load Member
    65
    48
    Jan 2, 2011
    Oklahoma City, Ok
    having a problem with low boost and high pyro temps. usually can pull 40lbs + of manifold pressure and pyro does not get over 650 - 700. now can hardly get 25-30 on boost and pyro gets over 800. do I have a high pressure leak on the turbo side or is twin turbo going south.
    This is on a 07 Pete, c-15 cat, that has had a mild pdi tune. any help or suggestions would be appreciated.
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    sounds like a boost leak. idle up to 1500rpm and squirt all conections with windex or soapy water and watch for bubbles. the cac you will probably have to pressurize to see if it will hold pressure.
    Ozdriver and Mr Dave Thank this.
  4. Ozdriver
    Ozdriver Heavy Load Member
    770
    1,394
    Oct 16, 2015
    Australia
    The smallest air leak can give quite a drop in power. Also I'd be checking end float and radial play on the on the turbos, I had one let go because of too much play. On my new replacement turbo there was absolutely no end float or radial play at all.
  5. Mr Dave
    65
    48
    Jan 2, 2011
    Oklahoma City, Ok
    found the problem, all the turbo bolts were broken and gone. shop replaced the center section of exhaust manifold, new bolts and gaskets. she is ready to truck again!
    SAR Thanks this.
  6. Superhauler
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    let me guess, top turbo. keep an eye on those bolts. they have a tendency to do that on a regular basis.
  7. Diesel Dave
    9,555
    31,731
    Jan 20, 2010
    Hesperia, Ca.
    I would figure with broken bolts, there would be a loud sound of exhaust leaking.
  8. wstar2003
    wstar2003 Light Load Member
    157
    195
    Jul 14, 2013
    Ah the dreaded Acert turbo studs claim another victim. Wonder how much labor money Cat has made off that (their own poor engineering) over the last few years. Too much weight hanging on that little an area. Better stock up on rocker arms, too. Good luck going forward.
