CAT C-16
Discussion in 'Experienced Truckers' Advice' started by Lazer, Mar 17, 2023.
  1. Lazer
    Lazer Road Train Member
    1,848
    2,978
    Jan 22, 2017
    Got a couple 2006 KW T2000 w/c-16, 10sp road ranger, 3.36 ratio, 22.5 low profile tires.
    What would be a ball park figure for mpg? We’re figuring on flatbed, or drop deck duty.
  3. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    My guess would be mid 5's. Maybe higher because of flatbed, I would be surprised if you got 6 or better.
    Bean Jr. Thanks this.
  4. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Way too many variables to guess accurately. 4 to 6 mpg depending on what speeds you're running and whats on the deck.
  5. Lazer
    1,848
    2,978
    Jan 22, 2017
    We’re just trying to get a rough idea, other than a few non-major issues, these trucks were parked when business dropped off in 2018-2019. Pulled them out of the fence row, and now starting to go thru them. One has the drive shaft bearing on the rearward differential is out, air compressor was shot but switched out with a truck that was in a wreck. The truck that was in the wreck will be the ‘donor parts’ truck for the other two.
  6. Cat sdp
    Cat sdp . .
    21,287
    76,077
    Apr 8, 2012
    Orion's Belt
    You sure that’s not a typo? T2000 with a C-16 ?
  7. Lazer
    1,848
    2,978
    Jan 22, 2017
    I’m no CAT expert by any means, I recall reading that was one of the offerings KW had in those model years.
    I’ve been told the c-16 of that era was a double turbo? I will double check the vin, and engine # latter next week when back at the yard.
  8. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,455
    6,860
    Oct 22, 2016
    North Dakota, Eh?
  9. Long FLD
    Long FLD Road Train Member
    12,830
    53,681
    Mar 4, 2015
    If it’s how it left the factory it wouldn’t have a C16 paired with a 10 speed. KW would’ve made them spec an 18 with a heavier driveline because of the 2050 torque. A C15 would be 1850 torque from the factory. And any Cat in 2006 would’ve been a twin turbo Acert. Either way, you should have a couple pretty solid engines. Won’t be the best on fuel but they will get the load moved.
  10. MM71
    MM71 Heavy Load Member
    760
    992
    Jun 28, 2008
    AZ
    im not a fan of zuckerburg ... but cat engine masters fb group is pretty keen on getting fuel mileage out of cats
  11. Magoo1968
    Magoo1968 Road Train Member
    2,055
    5,476
    Mar 18, 2021
    St Malo mb
    C13 is more likely with other specs aka the oil burner version in that era
