Cat c15 acert boost
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by united972, Sep 6, 2022.
  1. united972
    united972 Light Load Member
    157
    22
    May 26, 2016
    Hi guys I was wondering how much boost should this engine make stock its an 2006 acert engine in getting between 30-38 psi of boost and was wondering if that’s in spec
  3. ODR
    ODR Light Load Member
    66
    48
    Sep 30, 2013
    Tompkins, Sk
    My 475hp 1850 tq would do 52lbs of boost for me.
  4. bjytech
    bjytech Light Load Member
    244
    221
    Nov 9, 2013
    Sounds about right, it varies some depending on what it is set at but generally they max out somewhere between 35-45 if everything is working right.
    Seeing 52psi on stock fueling means your wastegate isn't opening like it should, which usually results in high drive pressure and heat.
  5. kranky1
    kranky1 Road Train Member
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    That would be about right. My BXS put up 55psi with the original 550 file in it.
