Cat C15 Fuel Problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brightlog, Jun 12, 2019.
  1. Brightlog
    Brightlog Bobtail Member
    43
    10
    Jun 8, 2019
    Maybe you fellas can help me out. I have a Cat C15 MODEL MNB. I’m losing prime over night but my fuel filters are filled. I had to spray ether then grabs. I’ve replaced my pump, fuel checks valves. Also I’m getting noise, from fuel housing filter to the pump. Like a suction sound lines vibrates also when I idle it high.
    Captain Mudsocks Thanks this.
  3. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    intersting. If your filters are filled, then it doesnt seem to be draining back to tank. Do you have a hand pump primer on filter housing or a block off plate? I hjad same issue with c12 and full filters. First replaced check valve in filter housing, that didnt work. Replaced the whole filter housing (160 bucks from cat). that didnt work, took offf block plate and installed cat hand primer pump. That fixed it. Only have to prime when changing secondary.
    Maybe bad block off, bad primer pump diaghpram or filter housing.
  4. Muddydog79
    Muddydog79 Heavy Load Member
    820
    2,147
    Apr 14, 2016
    Check all the fuel lines. I had one dry rot and it would seap out overnight. Wasnt dripping fuel anywhere, but the seapage was enough for it to lose prime. Replaced fuel line and never had another issue
  5. Muddydog79
    820
    2,147
    Apr 14, 2016
    Luckily the line i had dry rot was in a spot that was easily seen. Return hose, just looked wet but when i would bend the line the cracks were visible and it would drip out. Follow your lines all the way back to the tanks.
    spsauerland Thanks this.
  6. truck 307
    truck 307 Light Load Member
    179
    315
    Aug 11, 2014
    Your primary fuel filter will always be 60% full when checked as fuel will always bleed back past divider valve
    (Under center rear of bunk, on crossmember) and into tanks.
    If it's full, to the top, is being fed fuel from upstream ( next stop is pump) and or secondary fuel filter housing.
    Primer pump is commonly an issue, more so with the addition of bio blend fuel, which is, for the most part, alcohol, which dries rubber ( like in the hand primer pump plunger!!! )
    I'm not one to throw parts at a truck without proper diagnosis, but if the primer is old, replace it, its life is done anyway.
    Brightlog Thanks this.
  7. Chrisb
    Chrisb Bobtail Member
    6
    5
    Sep 17, 2013
    Check the return fuel line back of the head
    the o ring goes bad it happened to me once
  8. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    If all fuel lines check out and you have replaced the check valve and transfer pump. My guess is you have an injector leaking off over night. Does it smoke alot at first when you do get it started ?
    Oxbow and Brightlog Thank this.
  9. Muddydog79
    820
    2,147
    Apr 14, 2016
    Just a fyi, i have the same engine and my fuel filter is always full when i change em out.
  10. Muddydog79
    820
    2,147
    Apr 14, 2016
    Its a mbn. Doesnt have a hand primer.
  11. Superhauler
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    It should , unless someone removed it.
    Oxbow Thanks this.
