Cat c15 MBN
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by anthonyar4, Jan 12, 2021.
  1. anthonyar4
    anthonyar4 Medium Load Member
    431
    92
    Jun 8, 2019
    Anyone know how to test injection pump for failure. And what are possible symptoms?
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Do C15s actually have an injection pump. Thought those went out with the 3406C hybrid mechanical electronic pumps?
    Roger McG, black_dog106 and pushbroom Thank this.
  4. anthonyar4
    431
    92
    Jun 8, 2019
    Fuel transfer pump I meant sorry
  5. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    It is probably posted under the the search block, top right.
    Poor mans way connect a hose to the filter head and hang a gauge on the mirror. Probably looking for 100 Lbs, or at least 80.
    First sign is often surging power under load uphill.
    So what is going on with your truck?
  6. anthonyar4
    431
    92
    Jun 8, 2019
    Miss under load. Ran injector cutout test on it all good. Doesn’t miss when unloaded.
  7. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    Others much more qualified than me around here. A scanner hooked up under load is probably a good place to start. Maybe some inexpensive code readers are available.
    Sounds more like a sensor or harness problem to me.
  8. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,897
    Sep 20, 2015
    Southern Ontario
    I have a BXS that missed under load and had a difficult time getting my boss to understand that it is an issue that is still on going (Been that way for the year I drove it) and needed to be fixed.
    The engine would either have power or half power. No engine lights coming on.
    I just rebuilt the engine, has only 400 miles on it so far.
    Problem is that the truck sounds good and runs good to him when he uses it.
    But he hauls light loads (10 tons at least) while I haul loaded B-trains up to 50.
    The truck will miss a lot under load, like it was going break something.
    Several weeks ago I had the truck taken to a shop that has a Cat ET.
    He did the injector cut out at idle test. 1 turned off at time.
    Said there is no noticeable difference.
    I ask him to turn them all off but one.
    He said the engine won’t stay running if we do that. I said it’ll run on one cylinder.
    Sure enough, #1 and #6 couldn’t keep the engine running but #2,3,4,5 kept the engine running smoothly by themselves.
    So I replaced all 6 injectors.
    The truck hasn’t been on the road yet with the new injectors as it’s getting other work done at the moment.
    But I sure hope the problem is fixed.
    The current truck I’m driving now has a 3406E with over 1 million miles on the near original engine. This summer it had a missing under load with occasional missing at idle. The engine for years always smoked white when started up but always cleared up and went to work.
    We pulled all the injectors out and had them tested.
    5 tested low flow and one was non responsive.
    So all 6 injectors were put in. Fixed all the issues the engine had. Back to being smooth.
  9. pushbroom
    pushbroom Road Train Member
    1,788
    7,394
    Sep 1, 2012
    Injectors can miss under load but not when idling. You can cut out 5 cylinder and see if it runs on one like @Shawn2130 did.
    If it passes that you will have to take a laptop for a ride and cut out cylinders as the miss is happening.
    BoxCarKidd, black_dog106 and Shawn2130 Thank this.
  10. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    To answer your question on testing pump. Plug return line and hook gauge up. Idle engine..DONT REV IT UP ! Watch fuel pressure. Then unplug return line and run engine again. At low idle then high idle.. Checking pressure. Your miss sounds like a weak injector. Do manual cutout test and watch fuel flow rates for each injector.
    black_dog106 Thanks this.
  11. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    vise grip on return line and watch pressure
