Cat Engine Overhaul
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Fishell Trucking, May 24, 2014.
  1. Fishell Trucking
    Fishell Trucking Light Load Member
    128
    33
    Jan 11, 2011
    Raymond Montana
    I have had my engine overhauled twice in 6 years. The first being @ cat and they said the counter bore was within specs. So that being said is why I had it overhauled again last fall and not done by a cat house so it was done right. (Blowed headgasket and dropped linar ) Here is the question I have. Is on both rebuilds it uses oil ( 1gal to about 5000 miles). This may not be bad to some folks but don't ya think a new engine should not use any oil or am I just being to darn fussy? Right now I have 4900 miles on the oil and just added a gallon.
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    believe it or not that is pretty much normal if it is a new rebuild. I have had cat engines that don't use any oil and then some that use about 1 gal every 5000 miles like yours. the quality of cat parts are not as good as they used to be. I have had good luck with IPD over haul kits lately for a whole lot less in price than cat parts. and I used to swear by cat parts. the last three engines I done I installed the stiffer rings (heavyhaul rings) I don't care what anyone else says but those rings take about 25000 to 30000 miles to seat in. and that is running hard.
    puncher Thanks this.
  4. Fishell Trucking
    128
    33
    Jan 11, 2011
    Raymond Montana
    I guess I should've know that about the quality of parts. It is just like everything else you buy IT HAS A HIGH PRICE, LESS LONGEVITY AND OH YA POOR QUALITY. I couldn't agree more
  5. ENR
    ENR Light Load Member
    254
    50
    Oct 8, 2009
    Ontario
    Plus it looks like you are making some power and pulling some weight. Fuel consumed is a better indicator of work done than miles. I wouldn't be to worried at this point if I were you. It's not great... but neither is it worrisome .
  6. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    Cat makes an additive that helps during break in period. Not sure on part number but it's available at any caterpillar branch. I wouldn't worry about it personally I would just run it. I have seen 60k before.
  7. billandlori
    billandlori Medium Load Member
    357
    107
    Sep 5, 2010
    Stratford, Ontario, Canada
    I have a very similar build with 75,000 miles since I did the inframe about a year ago. I haul heavy too. It uses around a gallon every 10,000 miles now. It was a bit more at first. I found that idle time has a big impact of the oil usage. When I ran it over night this winter it used more oil.
    Good lookin truck by the way!!
    Bill
  8. Fishell Trucking
    128
    33
    Jan 11, 2011
    Raymond Montana
    Hey Thanks I like the truck and the power that I have now Just kinda pisses me of that u spend 25000 on an overhaul and it uses oil. But I guess oil is cheaper than allot of other things that could be hey wire.
  9. blackcrowntrans
    blackcrowntrans Light Load Member
    133
    73
    May 19, 2014
    I have an ipd kit in mine and I'm very happy
  10. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    Well, this should make you feel better, I just finished a total rebuild on mine (2000 miles ago) and I get the pleasure of putting in a gallon every 400 miles. Yup. You read right, if I could even make it 2 or 3000 I'd be a lot happier, never mind 5000. Every 18 hrs, usually every 2nd day, in goes another gallon. My mechanic told me it would be a couple hundred hours, so I am waiting and watching, adding and recording meticulously. I haul 140,000 lbs, so have no problem working it, but I have been backing off at 900-950 on the pryo. I don't know, maybe I am babying it too much? Just didn't want to risk wrecking anything after putting over 30$ into it.
  11. blackcrowntrans
    133
    73
    May 19, 2014
    How hot do you let your pyro go usually ? I ask because thats the same range I start to back out but I don't haul as heavy
