Cat engine serial number
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cajuncowboy654, Jun 4, 2019.
  1. Cajuncowboy654
    Cajuncowboy654 Light Load Member
    138
    34
    Jun 4, 2019
    So I'm trying to find the serial number for the Cat c-15 in my 05 Pete 379.
    It's not the original engine it was rebuilt and a different engine was used.
    Cant find any of the tags and what's left of the one on the oil cooler is not legible.
    The previous owner sent me this picture. Is the 2HS38562 the serial? I havent seen 2HS as a prefix before and cant find that anywhere
  3. mslashbar
    mslashbar Medium Load Member
    603
    821
    Jul 22, 2009
    elizabeth,co
    Its not 2hs, its 2ws and yes that's the serial number
    spsauerland Thanks this.
  4. Cajuncowboy654
    138
    34
    Jun 4, 2019
    Ok looked like an H to me
    Thank You
  5. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    2ws is a 1999 engine. You will be ELD exempt with that in your truck.
    EverLuc Thanks this.
  6. Cajuncowboy654
    138
    34
    Jun 4, 2019
    It has twin turbos, so that would make it an acert correct?
    Acerts were made after 2000?
  7. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    If it's got 2 turbos then it's not a 2ws. Sounds like you got a bunch miss matched parts on that engine.
    Accert twin turbo started in 2005. Same year as your truck. But your spacer plate under your valve covers says 2ws so who knows.
    Oxbow and spsauerland Thank this.
  8. Cajuncowboy654
    138
    34
    Jun 4, 2019
    That's what I was thinking too.
    That tag isnt visible anymore so I will try to see if I can find it etched in the block to see if it's actually say 2ws.
    It is definitely a twin turbo and has the iva/vva
  9. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Take a picture of block/ sculpted vs non. Think block stamping or plate should be passenger rear on block mid height around #5/#6 cylinder.
    pushbroom and swaan Thank this.
  10. EverLuc
    EverLuc Light Load Member
    295
    101
    Feb 18, 2013
    Once block is out and different head is used, adios serial number. You may find a serial number on the block....maybe.
  11. Navtech
    Navtech Light Load Member
    62
    43
    May 9, 2019
    I just typed that ESN into sis web and came up as 3406E which should not have twin turbos I guess you could use a 3406E block and install C15 parts on it same engine basically.
