CAT guys...
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Patriotleasing, Apr 30, 2022.
  1. Truckers Report Jobs
  2. Patriotleasing
    Patriotleasing Bobtail Member
    28
    Jan 1, 2017
    Anybody know what this is? Lube tech says he thinks it fell out my oil pan when he pulled the drain plug. Truck runs fine and everything seems to be in working other.
  3. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Got some end shots? Ive never redone the inside of the engine personally, but w.a.g. is its the end of a therm probe
  4. Arctic_fox
    4,489
    25,307
    Sep 16, 2016
    Its the thing-a-ma-jigger that allows the dodad to connect to the whirlygig which allows the thingamabob to do the whatchacall it with the dohickey.
    In all seriousness i think skall is correct. Looks like a probe end to me.
  5. Dave_in_AZ
    422,492
    Looks the pin from chain, or a keeper from somewhere.
    @wore out
    OLDSKOOLERnWV Thanks this.
  6. Star Rider
    Star Rider Road Train Member
    1,780
    18,159
    Sep 23, 2019
    Looks like the pin from the Jake Brake that rides in the injector arm.
  7. Star Rider
    1,780
    18,159
    Sep 23, 2019
    see page 5 and 8 Master Piston Assembly
  8. Patriotleasing
    28
    Jan 1, 2017
    Looks like the pin showed on page 8, thank you. Next question is is it safe to run the truck like that? Already dispatched on a load and hate to have to fall off it.
  9. skallagrime
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Its a risk, given that your jakes are now not properly functioning and you have at minimum a few washers and a spring still floating around in there. you need to pull the valve covers at minimum to assess what the damage is or isnt.
    Is that a death sentence and you need to tow it NOW, no, but it isnt wise to run it more than strictly speaking neccessary either. With any luck, all bits and peices fell into the oil pan damaging nothing on the way and the oil pickup strainer will keep them from causing further damage.
    I would definitely avoid using the jake if at all possible till you got it checked though
    Star Rider and AModelCat Thank this.
  10. AModelCat
    164,258
    Its a ticking time bomb. Might run forever, might make it 5 minutes. Might be leftover from a repair from before you owned it. If the jake's working fine and what not I'd say the last scenario is most likely. I still would investigate before I put the truck back in service. A couple hours of downtime to pull the valve covers and check things over beats being down a few weeks with an engine failure.
    Star Rider Thanks this.
