Cat manifold C15
Discussion in 'Peterbilt Forum' started by Loaderlou, Oct 19, 2014.
  1. Loaderlou
    Loaderlou Medium Load Member
    342
    131
    Feb 24, 2014
    Hi guys, I have a 2003 C15 6NZ. It has a 3 piece manifold with 2 clamps that have a fabric at the connecting points. Does anyone know if I can use something like a wood/coal stove uses in place of the fabric that cat sells. It seems to lose its seal pretty quick. Kind of desintergrates after a while.
  3. rollin coal
    rollin coal Road Train Member
    13,607
    27,972
    Mar 29, 2008
    TN
    Chunk it in the scrap pile and get a PDI manifold. They're pricey but they don't leak.
    Loaderlou Thanks this.
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    what he said^^^^^ the new pdi manifold has been redesigned with the Cummins seals for the slip-joints. works really well. just don't put them in backwards when you install them.
  5. Flightline
    Flightline Road Train Member
    2,345
    1,167
    Oct 1, 2011
    Almost There
    I'd opt for the PDI manifold as well. I think that is the route I'll be going soon.
    but if money is a tight issue, they do make an exhaust wrap with silcone spray. It's designed to take the exhaust temp directly at the manifold.
    They sell it at most parts stores and at Pittsburg Power. Comes in 2" roll and have to buy the spray separatley.
  6. Loaderlou
    342
    131
    Feb 24, 2014
    Thanks for the comeback guys, much appreciated. I should have done the PDI manifold when I did the turbo, but for now I have to keep replacing the fabric under the clamps. Trying to find a better product that will last. Thanks again. Keep the shiney side up.
  7. Cat sdp
    Cat sdp . .
    21,296
    76,123
    Apr 8, 2012
    Orion's Belt
    What they said........
  8. rollin coal
    13,607
    27,972
    Mar 29, 2008
    TN
    So shiny and new! They don't stay that way forever. Mine's been on there a little over 2 years and the coating on the outside is flaking, peeling, has some surface rust. But no leaks.
    swaan and Cat sdp Thank this.
  9. Flightline
    2,345
    1,167
    Oct 1, 2011
    Almost There
    Bid they improve your fuel economy as stated on the web site?
    Can you tell any difference in top tubo boost pressure?
  10. Cat sdp
    Cat sdp . .
    21,296
    76,123
    Apr 8, 2012
    Orion's Belt
    Yes my fuel economy is about 3/10ths better..... I haul heavy.
    My turbo boost is the same , however when I romp on it on a hill it does not heat up as fast.......
    I blew the original exhaust manifold gasket ... So it was a no brainier.
    I'm very happy with the piece .
  11. rollin coal
    13,607
    27,972
    Mar 29, 2008
    TN
    Boost unchanged EGT's definitely went down but I don't know about mpg improvement couldn't really say. When my motor went down the stock one came off during the inframe and that one went on.
