cat mbn
Discussion in 'Trucks [ Eighteen Wheelers ]' started by petermobile, Nov 24, 2013.
  1. petermobile
    petermobile Bobtail Member
    i have a 2004 pete with cat mbn was rebuilt last year and they say it is set at 450 hp i am not happy with fuel mileage or power pulling hills was thinking of doing ecm upgrade but dont know if it is worth the money. they say i will get 715 hp to flywheel but will it really help with mileage or power.
  3. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,483
    Oct 18, 2009
    Waynesburg, Pa
  4. j-dawg
    j-dawg Light Load Member
    164
    47
    Dec 21, 2011
    Oil town, Ab
    Flash it too a pre-mbn file. It'll make it a different truck.
  5. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    There's some files out there for mbns that leave the ID as a mbn. That means you have a chance of warranty one it. I got one put in mine and it runs with 550s now and picked up 3/4 mpg. Got rid of the high exhaust temp also. Just nicer to drive all the way around.
  6. rollin coal
    rollin coal Road Train Member
    13,576
    27,897
    Mar 29, 2008
    TN
    Much cheaper to put an old 6NZ file in it and upgrade the turbo than to spend big bucks on PDI, Bullydog, etc. It'll run great, better than every other 500/600up out there, and get good fuel mileage too as long as you drive it right. I'm sure 700+ hp is fun but only if you got money to spend on it, gotta pay to play.
    j-dawg Thanks this.
  7. bad-luck
    bad-luck Road Train Member
    3,422
    6,301
    Nov 16, 2013
    Baltimore, Maryland
    Cat has never been known for its fule milage... if you turn your motor up to 715hp you will most likely burn up your clutch because it is not rated for that hp and torque.byou will need to replace it with a 2250 torque clutch
  8. ModZZilla
    ModZZilla Bobtail Member
    17
    8
    Sep 22, 2013
    AGREE--I'm running a MBN at 800hp and hardly ever use it, but if you keep your foot out of it you can see 6.8mpg pulling 98k of logs.
    j-dawg Thanks this.
  9. sandman1976
    sandman1976 Medium Load Member
    411
    47
    Mar 5, 2009
    burgaw,nc
    what do u have done to ur mbnk?
  10. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    back flash to 6nz great stuff done alot people love it.
  11. ModZZilla
    17
    8
    Sep 22, 2013
    PDI tuned ECM, PDI turbo and manifold, C18 marine cam.
    Cetane+ Thanks this.
