CAT MPG
Discussion in 'Ask An Owner Operator' started by Bearbait69, Aug 2, 2023.
  1. Bearbait69
    Bearbait69 Bobtail Member
    20
    5
    Apr 29, 2021
    Comment your truck, sleeper size or day cab, motor, hp, transmission, rears, tire size, wheelbase, what you pull and the overall weight of load and truck, speed and rpm, and what mpg you get.
  3. Oxbow
    Oxbow Road Train Member
    13,645
    141,412
    Nov 24, 2015
    89 378 daycab with tag axle
    3406B
    425ish
    18918B
    46k 4.11/5.29
    11 24.5
    RGN
    Max 140k gross
    Fast as I can - 1500 to 2100
    IFTA 4.8 to 5.1
    Edit to add:
    Pto use for RGN (wet kit)
    About 40% empty miles. Majority of loaded miles around 113,000.
  4. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    3406e (1LW)
    94 t600 midroof (60ish inch sleeper), 13 spd, 3.36 rears, 22.5 tall rubber, flatbed, 10-49k lb, 485 hp, speed 68ish, running close to 1400 rpm
    roughly 5.5-6.5 mpg depending on load weight, height, terrain
    Wheelbase 285
    Truck 2
    3406e (6ts)
    98 t800 aerodyne lowroof, sleeper roughly 30inch., 9 spd, 3.73 rears, 22.5 short rubber, flatbed, 10-51k lb, 450 hp listed (not confirmed, guessing its actually only 400hp), speed 65ish, running 1600 rpm
    roughly 6.5-8 mpg depending on load weight, height, terrain,
    Wheelbase 240ish
    Reason for edit: Add engine model
    Old mark, JoeyJunk and Oxbow Thank this.
  5. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,031
    Dec 31, 2010
    Washington, PA
    1998 FLD120
    Series 60 12.7
    485HP
    3.36 rears
    10 speed (hate it but 13’s are $$$)
    Pulling sandbox in oilfield. Lots of short trips, hills, backroads OH, WV, PA, idiling. That said, RPM is inconsistent.
    Grossing 75-76K
    5-5.5
    Edit: 48 inch flat top with a really sweet roof fairing
    exhausted379, Old mark and Oxbow Thank this.
  6. Old mark
    Old mark Light Load Member
    77
    197
    May 22, 2016
    1998 pete 379. 3406e 5ek. 18 speed. 3.90 rears. 70 inch sleeper. 11r22.5 tires. 38-20 hopper train. 105,500 ish. 75 mph 1700 rpm. 3.6- 4 mpg. 550 hp.
  7. abyliks
    abyliks Road Train Member
    4,102
    9,639
    May 2, 2010
    ludlow MA
    96 w900 day cab, pulling a bucket, 46k 4.33 rears w/15 over, 1124.5, ~100k one way, empty the other, 5.8, I get about the same with the n14 3.55/18 22.5 on the same run
    Oxbow Thanks this.
  8. Long FLD
    Long FLD Road Train Member
    12,828
    53,673
    Mar 4, 2015
    T800 with 3.70’s and tall 24’s running 105k gross in the PNW with a flatbed I was low 5’s consistently.
    Oxbow Thanks this.
  9. Arctic_fox
    4,502
    25,384
    Sep 16, 2016
    579 with a paccrap MX13 @455
    3.28 gears
    13 speed
    232 wheel base
    70 inch sleeper
    22.5 tires
    75/1410 rpm
    I pull buckets so i am never under at least 79K usually pretty close to 80K and i haul nationwide so everything from VA down to FL across to UT. ifta was 6.9MPG last year.
    Oxbow Thanks this.
  10. SmallPackage
    5,774
    18,532
    Dec 20, 2019
    Marion Texas
    ‘99 FL60 3126B baby Cat. 6speed Spicer. 3.90 Rockwell 11r22.5. 33,000 gvw. 75 mph on the 2400 rpm governor all day pushing wind. 7.2 mpg. Idled probably 6 hrs a day total most days at p&d’s.
    ‘73 Pete 352-110 PaceMaker. 1693 380 hp. 2100 rpm. RTO12513. 4.11 Rockwells. 10-22 rubber. 4.5 mpg no matter what.
    ‘67 Pete 351. NTC350-855. RTO12513. 4.11 Rockwells. 11r24.5 rubber. 2100 rpm. 7.4 mpg. Bobtail 8.2 mpg.
  11. AModelCat
    164,450
    Remember my old man saying he was getting around the mid 4's with a 475 hp C-15. T-800 tridrive, 18 speed, 4.33 rears, 24.5 tires. About 120k lb gross.
