cat oil pump
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bean farms, May 6, 2012.
  1. bean farms
    bean farms Light Load Member
    118
    Feb 25, 2011
    red boiling springs tn
    i was wondering if you could shim the oil pump relief spring on a 3406c model it holds about 20 psi at idel i would like to see it at 30 psi at idel how do i need to go about doin this thanks
  3. SL3406
    SL3406 Medium Load Member
    551
    1,502
    Jan 10, 2011
    Oklahoma
    Yes I have always shimmed the spring on all of mine with washers. Unfortunately it's trial and error to get the pressure where you want it.
  4. bean farms
    118
    Feb 25, 2011
    what does one washer do far as pressure goes id like to get 10 psi at idel is what im goin for and the spring is the one sticking out toward the back of the motor isnt it
  5. SL3406
    551
    1,502
    Jan 10, 2011
    Oklahoma
    Yes it's the spring that sticks out the back of the oil pump. I put the washers on the plunger end of the spring. It depends on how thick the washers are obviously, but it will probably take more than one to raise it 10 pounds. 20 pounds of pressure at idle is really low for a Cat. How many miles are on your rod and main bearings?
  6. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    15 is minimum spec. at operating temp.
  7. booboo
    booboo Bobtail Member
    39
    4
    Jan 17, 2009
    gainesville,ga
    What rpm is it truning at idle?
  8. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    my cat runs about 25 lbs at hot idel fresh rebuild 65 on the road
