Caterpillar running rough
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Austinvohs1996, Jul 25, 2021.
  1. Austinvohs1996
    Austinvohs1996 Bobtail Member
    Jul 25, 2021
    HELP!!!
    Caterpillar 3176 in 1991 Pete 357
    This problem started a couple a months ago. Started happening every so often and now getting worse. I’ll get a engine light and truck misses for a second and comes right back. Only thing I can think of is fuel delivery issue like air getting sucked from somewhere or wiring issue. When this first started it was random throughout my day. Happening very lightly. Now it seems to be happening worse and very harshly. Seems to happen a lot more in the morning. Specifically about 10 or 15 mins after start up. I’ll let the truck warm up for a few and it will start missing and throwing a engine light. Gets worse after leaving the yard for about the first half hour of my morning then seems to go away and run fine all day long.
    I’ve taken it to two mechanics already and they can’t find any stored codes and they’re not able to diagnose it because of how intermediate the problem is. I’ve changed fuel filters , ran injector cleaner , changed out the muffler.. batteries are good. Truck doesn’t smoke… Can’t find and loose grounds. Don’t know what else to do.
    NEED HELP
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    maybe the ecm.. my buddy's cat/pete did the same. cold start run like sheetz for 30 minutes. then run fine. it turned out to be his ecm.
  4. bad-luck
    bad-luck Road Train Member
    3,431
    6,319
    Nov 16, 2013
    Baltimore, Maryland
    1st thing that comes to mind is a bad injector. I would either get a Thermo heat gun and check temps on all the cylinders when it is missing, they should all be about the same temp, the one that is not is you culprit. Or unplug the injectors one at abtime. When you unplug an injector and your miss goes away, you found the bad injector.
  5. SWMO_Transport
    SWMO_Transport Bobtail Member
    22
    35
    Feb 11, 2018
    Definitely use the heat gun trick. Sure fire way to diagnose a poo poo injector
  6. Austinvohs1996
    Jul 25, 2021
    Also forgot to mention there is a small diesel leak at the bottom of the ecm. Don’t know if that would be causing the issue
    Magoo1968 and truckdriver31 Thank this.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Things are not the same as they once were. People got divorced and it was done. Now they get remarried and or just shack up. Some live happily ever after or not.
    Point being a piece of paper does not fix the problem.
    What is the code that goes with the check engine light?
    Many loose the thought of what would cause this if there was no computer. Sight glass in fuel line to check for air is a good start.
    spsauerland, Magoo1968 and AModelCat Thank this.
  8. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    What is your fuel pressure off the filter head when it is mucking up?
  9. AModelCat
    164,594
    If the engine light comes on, there should be a fault associated with it. CAT is pretty good about logging every event a fault code. The shops that scanned it, did they give a printout of the logged faults and events? Where the using CAT ET to read the ECM or just a generic scan tool?
    spsauerland Thanks this.
  10. Magoo1968
    Magoo1968 Road Train Member
    2,056
    5,477
    Mar 18, 2021
    St Malo mb
    That ecm is cooled by fuel .. it’s possible that leak is allowing air into fuel system. Mr Haney told a member to bypass fuel line and put a stand-off behind ecm to move it away from the block to allow airflow behind it.. ecm is unrepairable if leaking fuel and expensive. If you get a year or 5 extra with his fix it seems worth it.
    BoxCarKidd and spsauerland Thank this.
  11. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Small fuel leak= lose of fuel prime, hard start, and white smoke.
    BoxCarKidd, Magoo1968 and Oxbow Thank this.
