Cb antenna
Discussion in 'CB Radio Forum' started by International2020, May 28, 2024.
  1. International2020
    International2020 Light Load Member
    62
    12
    Dec 17, 2023
    South Carolina
    Can someone show me how this #### thing works. It says u can extend it with the longer whip u see but idk how the hell u do it. IMG_4238.jpeg
  3. International2020
    62
    12
    Dec 17, 2023
    South Carolina
  4. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,945
    3,315
    Jun 10, 2019
    It ain't rocket science, man.
  5. Diesel Dave
    9,604
    32,243
    Jan 20, 2010
    Hesperia, Ca.
    Don’t forget once it’s on to have the SWR checked.
    cuzzin it and International2020 Thank this.
  6. drivingmissdaisy
    1,945
    3,315
    Jun 10, 2019
    Boy ain't that the truth. I bought the same antenna, man that thing looked incredible, couldn't get the SWRs below 4:1. Had to return it and get one with just a coil. That lasted until I tried to change trucks with it and broke the base trying to unscrew the #### thing.
    I've found this simple one has given me the best performance for decades. That style, a simple center loaded antenna, nothing fancy. The antenna "thinks" its 102" long because it technically is, just not sticking straight up where it could hit something. This is the only antenna I was able to achieve a perfect 1:1 SWR with. 25 bucks you can't beat it with a stick.
    https://www.nfm.com/roadpro-center-loaded-cb-antenna-1000-watts/60614153.html
    International2020 and Diesel Dave Thank this.
  7. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Well if a # of different antenna dont tune and only a cheaper one does,that would tell me that something is up and not that the cheaper ant is better..
    jdchet Thanks this.
  8. jdchet
    jdchet Medium Load Member
    542
    771
    Sep 3, 2012
    NE Ohio
    Really?
    JD
  9. International2020
    62
    12
    Dec 17, 2023
    South Carolina
    Actually it kinda was
  10. rabbiporkchop
    9,689
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    You should be able to achieve the same results with this one, and this one won't break.
    BK300150 - 59" Oil Filled CB Antenna
    Diesel Dave Thanks this.
  11. Diesel Dave
    9,604
    32,243
    Jan 20, 2010
    Hesperia, Ca.
    I had a pair of those back in the early 80’s, they were called “Audio Kings” back then.
    rabbiporkchop Thanks this.
