Cb test equipment
Discussion in 'CB Radio Forum' started by Batrobes, May 25, 2018.
  1. Batrobes
    Batrobes Bobtail Member
    9
    4
    May 24, 2018
    Altoona, Wi
    Ok so for those of us who would like to learn a little more about our radios!
    What in your opinions would be good test equipment. Watt meters, oscilloscopes, tone generators, etc. Things like do you prefer attenuators, or a regular dummy load (dry or wet)
    What's reliable, what's not? Did you find a cheap brand that works great compared to the big name brand?
    6wheeler Thanks this.
  3. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
    You would want a decent watt meter with a peak envelope power setting.
    A good lab grade freq counter.
    A 50mhz or 100mhz scope.
    A signal generator that will do up to 30mhz at least and able to add a 1000hz tone. Also they have an app for that too.
    A good digital volt ohm meter.
    An old vacuum tube volt meter.
    I picked up an old Sencore CB-42 test station on eBay and had a good tech refurbish and calibrate it. He changed caps out too.
    Everything I listed can be bought cheap on eBay. If you have just what I listed, you will have more equipment than 99% of the cb hack shops out there.
    Disclaimer:
    I'm not a tech, but I keep the good ones busy..
  4. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    oscilloscopes is interesting to me but so expensive. I looked for a used one but they are hard to find and someone like me I really don't know what I'm looking for being that I'm new at it.
    Good intelligent topic for discussion. Thanks
  5. delta5
    1,193
    7,404
    Sep 9, 2010
    Just do a search on eBay for 50mhz oscilloscope. Tons of them on there every day.
  6. Ridgeline
    22,721
    122,982
    You guys, the first thing to get for any test equipment is a book of basic electronics.
    Delta, read your list again, a vtvm may need work to get it accurate.
    6 scopes are cheap, bet you spend more on a night out with your better half than you would with a scope.
  7. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    This should give you an idea of what test equipment is needed, and how to hook it up.
  8. Night Stalker10
    1,697
    1,271
    Jun 26, 2017
    You don’t necessarily have to buy all the equipment shown above. you can buy a unit that has some of it built in. Like a B&K 1040 as an example.
  9. Ridgeline
    22,721
    122,982
    Guess what guys, you are putting the cart before the horse.
    Lets start with a book on basic electronics and then a good dummy load and a good watt meter. YOU don't need a scope, you don't need a spectrum analyzer, you don't need all that other crap, you need to learn the basics and build from there.
  10. Night Stalker10
    1,697
    1,271
    Jun 26, 2017
    That is definetly true. But I figure since they really wanted to know what it takes to work on a radio, I would at least give them an idea of what they will need equipment wise.
  11. delta5
    1,193
    7,404
    Sep 9, 2010
    I'm not too good with component level diagnostics yet, but I pretty much have alignment figured out.
