Cdl pretrip abs light
Discussion in 'Trucking Schools and CDL Training Forum' started by tyler7191, Jan 15, 2025.
  1. tyler7191
    tyler7191 Bobtail Member
    5
    Jan 4, 2025
    I was going to take me cdl drive test soon. My trailer abs light intermittent comes on and off depending on the day and its mood. As long as I mention checking it is that good enough or does it need to be functioning properly to let me pass? This is on the trailer only the truck works fine. Thanks!
  3. FLHT
    FLHT Road Train Member
    1,425
    2,538
    Aug 2, 2014
    Might want to fix that.
    Easy ticket.
    If you are going to lease on with a company most will inspect your equipment .
    Thats a fail on inspection.
    northstarfire0693 Thanks this.
  4. northstarfire0693
    northstarfire0693 Heavy Load Member
    865
    598
    Jul 1, 2006
    NC
    If its on and off. First simple solution would be to check for corrosion on all connecters. Generally, if its a failure with the ABS modules on the trailer. It will stay on all the time. with what you are describing, sounds like a wiring issue.
    Bean Jr. and omaharj Thank this.
  5. FozzyNOK
    FozzyNOK Road Train Member
    2,480
    3,824
    Jul 18, 2007
    Oklahomistan
    If you can get it repaired, it would be the best... but honestly, the CDL test isn't a real inspection.. They are testing whether or not you can conduct an inspection.. as long as all your lights and signals work... you should be OK
    firemedic2816 Thanks this.
  6. Rideandrepair
    17,532
    56,814
    Aug 8, 2015
    Could be an early warning sign of a loose wheel end. Might want to play dumb if it comes on during your pre trip portion of the road test. Maybe mention it needs attention for that very reason. Once you get the License you can run it till the whole hub/drum/wheels/tires fall off. Seriously, it’s a real concern. Get it fixed, just in case.
