CDL Test in Dually
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Trident39, Apr 28, 2019.
  1. Trident39
    Trident39 Bobtail Member
    16
    8
    Jan 21, 2019
    Hey All, I'm ready to take my CDL Class A test in my dually. I have a few questions...
    What kind of trailer do I take the test with? Can I use any regular trailer ie; gooseneck, bumper hitch, or does it need to be a trailer over 10K? Meaning i'd need to bring someone with a CDL with me..
    Thanks!
  3. ZVar
    ZVar Road Train Member
    10,911
    23,830
    Sep 10, 2010
    Flint, MI
    You will get a CDL in the vehicle type you test with.
    To get a CDL A with a 3500/f-350 you would need a trailer with a GVWR over 10k lbs and the GCWR over 26k lbs.
    Some possible restrictions are:
    Automatic transmission if not tested w/ a manual.
    No air brakes.
    No 5th wheel if testing with a bumper pull or gooseneck. Has to be a 5th wheel.
    And yes, you will need a valid driver to take the rig to test with.
    Bigbubba1 Thanks this.
  4. Trident39
    16
    8
    Jan 21, 2019
    So, I have to install a fifth wheel?... My trailer will be a gooseneck.
  5. ZVar
    10,911
    23,830
    Sep 10, 2010
    Flint, MI
    I you wanna not have that restriction then yes.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,141
    Mar 5, 2016
    White County, Arkansas
    Your trailer has to be over 10,000 pounds or more in weight total plus the towing vehicle to make it a CDL A license.
    You will not be getting airbrakes with that.
    It is a combination vehicle so rates the Class A. You will be using a 5th wheel in the bed of your truck. The weights involved are just too heavy for bumper hitches.
    Hopefully your dually is a manual so you can not have that auto restriction put on.
    Bean Jr. Thanks this.
  7. parkerhotshot
    parkerhotshot Bobtail Member
    If I am planning on doing hot shot do I need a fifth wheel or will a gooseneck be sufficient ?
    Also what would be the downside to having auto restriction if I will only ever be driving my truck?
  8. ESAFO
    ESAFO Light Load Member
    96
    224
    Jan 2, 2022
    Hubbard, Oh
    Gooseneck is fine mainly used for flatbed freight/vehicles, 5th wheel hitch mainly used to haul RV's/campers.
    There is no downside to having automatic restriction, as long as you never plan on driving commercially with a standard shift vehicle.
  9. Wasted Thyme
    7,729
    38,309
    Jan 27, 2020
    GOAT watching
    Automatic restriction won't be an issue at all.
  10. 24kHotshot
    24kHotshot Heavy Load Member
    801
    874
    Feb 19, 2019
    New York
    Gooseneck is not fine for car hauling. Most of the wedge trailers you see laying on their side are Gooseneck ball.
    Gooseneck is ok for freight.
    Single pivot 5th wheel is good for cars
    And double pivot 5th wheel is for rv.
    Single pivot only tilts front/back and not side to side like an rv double pivot plate.
  11. ESAFO
    96
    224
    Jan 2, 2022
    Hubbard, Oh
    My bad I should've been clear about that, I didn't mean to lead him to believe I was talking about a Wedge trailer.
    I meant machinery, bobcats, scissor lifts things like that.
    Not saying you can't throw a car or two, motorcycle on with a side by side & so on.
    24kHotshot Thanks this.
