Centramatic vs fluid
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by truckerbangin, Oct 10, 2021.
  1. truckerbangin
    truckerbangin Light Load Member
    268
    45
    Jan 22, 2013
    Has any one ever fluid balanced their wheels instead of running the centramatic wheel balancers. Looking for pros and cons of fluid balancing vs centramatic balancers
  3. Big Road Skateboard
    6,880
    38,791
    May 2, 2021
    Balance beads are an alternative to centramatics. I would not use a liquid.
  4. John E.
    John E. Light Load Member
    239
    973
    Apr 4, 2021
    New Brunswick
    H2O probably wouldn't work. On a cold mornin that is.
  5. Goodysnap
    Goodysnap Road Train Member
    3,756
    9,153
    Jul 12, 2017
    I was troubleshooting a vibration on an old ladies fwd chrysler car, dont recall the model. Spun up the rear wheels with the spinner and the RR Shook like it was seporated tho it ran true as can be with little runout if any.
    Dismounted the tire and got blasted in the face with what was proly a dozen or more cans of the cheapest fix a flat known to man. Looked like water and newspaper shavings. Repaired the nail hole, cleaned out the tire and all was good.
    Ditto to no fluids for balancing.
    blairandgretchen and daf105paccar Thank this.
  6. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    607
    Nov 11, 2010
    Wyoming
    These are semis not farm tractors or heavy equipment.
    Balance beads have served me well over the years, I actually just ordered my first set of centramatics to try out. A 20k front axle on a 212 wheelbase truck with Chalmers out back needs all the help it can get. Especially when you're in bumper pull mode and you actually have less weight on your steers loaded than empty!
    Oxbow Thanks this.
  7. Willis Inc.
    Willis Inc. Bobtail Member
    44
    30
    Nov 2, 2020
    Harrisburg, PA
    Windshield washer fluid is used as weight in tires, don't know about balancing them.
    Willis
  8. God prefers Diesels
    4,198
    22,264
    Jun 26, 2020
    South Texas
    When you use beads, is that just for the finishing touch after you balance them as normal? Or do you just run beads and not balance them at all?
  9. Goodysnap
    3,756
    9,153
    Jul 12, 2017
    I wouldnt do both. They are considered a cheaper or convenient alternative to conventional spin balancing.
