Century N-14 Derating
Discussion in 'Freightliner Forum' started by mrbamcclain, Sep 5, 2012.
  1. mrbamcclain
    mrbamcclain Light Load Member
    258
    116
    May 25, 2011
    Hammond, La
    I've been getting a CEL and it reads a #4 injector open. Took it into Freightliner and the tech checked the tested the injector and the internal harness and all tested within spec. Replaced the pass thru connector. About an hour down the road truck does the same thing. Haven't made it back to the dealer to have them check it again.
    Symptoms are crazy though.
    If the fuel level gets low it's usually when I have the problems. Low as in say 40 gallons. Sometimes if the cruise is set it'll back itself down to 55-60 and occasionally pick up. First I was thinking the TPS harness, but now I'm not so sure. If driving with the pedal and I let off the throttle that's when it starts. Sometimes a key cycle will get things back to normal but not always. Any thoughts? Thanks in advance.
  3. Taildragon
    Taildragon Heavy Load Member
    723
    449
    Jun 22, 2012
    Indiana
    I would check the ground straps from the frame to the engine and frame to the cab.
  4. PST
    PST Light Load Member
    125
    53
    Sep 7, 2009
    USA
    Fuel pump or lift pump?
  5. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    N14 dosent have a lift pump you are getting ready to lose an injector I would say the selinoid is intermittent shorting out
  6. mrbamcclain
    258
    116
    May 25, 2011
    Hammond, La
    Would it be better to change the one or change them all out at once?
  7. truckmechanic
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    I like to change them all at the same time buy its your choice have the inj cups checked for leakage and run the overhead
  8. mrbamcclain
    258
    116
    May 25, 2011
    Hammond, La
    I ordered a replacement injector from my local shop. He wants $850 to change the one injector. Ouch!
    How hard of a job is it to replace one of these?
    Do I need to change the jake gasket as the guy is telling me if I replace this injector myself? The valve cover gasket is reusable right?
    I pull the harness on each injector and they are dry all except the #4. Is that an indication of some leakage there from the injector?
  9. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    It sounds like #4 is going or gone.
    They make 2 different injectors for the N-14 PX (performance and new) and RX (rebulit) I believe. The PX runs around 450.00 and the RX I think is around 300.00. Labor on the #4 injector and adjusting the valves on #4 only should be around 200.00 and a new jake gasket. The valve cover gasket will be fine. So 550.00 -700.00 range.
    mrbamcclain Thanks this.
  10. mrbamcclain
    258
    116
    May 25, 2011
    Hammond, La
    Does the injector go into some type of heavy duty cycle or something when the fuel gets low?
    It's odd because I only get derating when the fuel gets down to about 40-50 gallons. As long as I keep it full I have no problems, that's killing my pockets though. Only one time in the last few weeks that this has been happening did it happen while I had more fuel.
    What exactly is running the overhead and should I have it done as well at the same time?
  11. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    Running the overhead is adjusting all the valves and injectors.
