Chains length
Discussion in 'Heavy Haul Trucking Forum' started by zinita17601, Nov 11, 2023.
  1. zinita17601
    zinita17601 Road Train Member
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    What is the ideal length for 1/2 securement chains?do i need a combination of lengths maybe?please advise thx
  3. IH Truck Guy
    4,874
    56,535
    Mar 2, 2008
    Purgatory
  4. Diesel Dave
    9,565
    31,846
    Jan 20, 2010
    Hesperia, Ca.
    What are your intentions for 1/2 use ? Standard is 5/16’s.
    cke, singlescrewshaker and Tb0n3 Thank this.
  5. 50WT
    50WT Road Train Member
    2,900
    26,540
    Dec 26, 2015
    We use 1/2 and 3/8 on our detach trailers 55 ton.
    and 5/16 and 3/8 on the stepdecks.
  6. zinita17601
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    Rgn,heavy haul
  7. Diesel Dave
    9,565
    31,846
    Jan 20, 2010
    Hesperia, Ca.
    Got it. Was just curious since I only deal with 5/16’s. I carry a few 3/8’s shorty’s(for extensions). I’m aware rgns and equipment haulers use 3/8’s and 1/2. For my age there pretty heavy to man handle, but will use if necessary. In any case, I have double up(different hook locations) on the 5/16 if needed.
  8. Tb0n3
    Tb0n3 Road Train Member
    4,733
    9,636
    Oct 5, 2012
    Earth
    As short as you can get away with. Those big boys aren't super easy to haul around. It's not unmanageable but it makes for significantly more work.
  9. RickyDickyDo
    RickyDickyDo Heavy Load Member
    852
    896
    Nov 22, 2010
    Loveland, Colorado
    Hauling yellow iron. I carried 1/2" grade 80. 4'(6) 6'(6) and 10'(4) chains. Carried a couple of 3/8 10' chains. Had 120s at the shop when needed.
    cke, singlescrewshaker and zinita17601 Thank this.
  10. beastr123
    beastr123 Road Train Member
    2,942
    24,143
    Jan 2, 2014
    Moose Jaw SK CAN
    For 1/2 inch I carried 4-6ft and 2-10ft all with a grab hook on one end and a slip/foundry hook on the other. I also had 4-6ft 3/8 with the same hooks as well as 8-12ft 3/8 and 2-20ft 5/16 with grabs on both ends. That was the minimum.
  11. Razororange
    Razororange Road Train Member
    2,696
    25,680
    Dec 20, 2011
    Milwaukee, WI
    If you're only hauling heavy equipment you'll be fine with mostly 5' and maybe a few 10'. 1 slip hook and 1 grab hook on each chain so you can use whichever end you need.
    If you need longer than that just hook 2 together.
    cke, singlescrewshaker, stwik and 3 others Thank this.
