changing fuel filter
Discussion in 'Experienced Truckers' Advice' started by Ei, Feb 16, 2015.
  1. Ei
    Ei Light Load Member
    79
    7
    Aug 18, 2013
    Northeast
    was changing fuel filter today noticed it was full temps are very cold sub zero last few days, filter was full this morning, I did used howe's in the last few days in the tanks, but couldn't get the filter drain valve to drain, does this require the vent cap to be removed to get it to drain??? i think it may be frozen at the bottom but the truck started fine, I still changed the filter, truck running but new fuel filter shows just about full again because i didnt drain it, help please. '05 s60 12.7
  3. Ei
    79
    7
    Aug 18, 2013
    Northeast
    first time doing this my self
  4. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    is your motor a 12,7 detroit?
  5. Ei
    79
    7
    Aug 18, 2013
    Northeast
    yes it is Jbourque
  6. 062
    062 Road Train Member
    6,311
    33,940
    Oct 20, 2013
    Are we talking about a Davco,the one with the clear plastic dome? If so mine normally takes a few miles to pull down.
    x#1 Thanks this.
  7. Ei
    79
    7
    Aug 18, 2013
    Northeast
    Yes the exact one, should I check it tomorrow after I drive it? What the worse case scenario driving with a full fuel filter?
  8. Ei
    79
    7
    Aug 18, 2013
    Northeast
    It was at the full line but was just idling
  9. 062
    6,311
    33,940
    Oct 20, 2013
    Did you fill it to the top or did it rise after you started the truck? I normally fill mine about half way.
  10. Ei
    79
    7
    Aug 18, 2013
    Northeast
    Rise up after I started
  11. ampm wayne
    ampm wayne Heavy Load Member
    945
    746
    Jan 13, 2009
    bloomington,in
    With the engine shut off loosen the top cap and then drain some fuel out. It will not drain well unless you loosen the top cap.
