cheap antenna analyzer
Discussion in 'CB Radio Forum' started by rabbiporkchop, Mar 11, 2016.
  1. rabbiporkchop
    9,689
    6,541
    Feb 9, 2012
    Wapwallopen, Pa
    Watch "SARK100 Antenna Analyzer" on YouTube
    $86.00 on Ebay
    TheDude1969 and Bout Z Thank this.
  3. rabbiporkchop
    9,689
    6,541
    Feb 9, 2012
    Wapwallopen, Pa
    This one has bluetooth and usb port.
    Watch "Mini60 Antenna Analyzer" on YouTube
  4. Ridgeline
    22,706
    122,380
    You know I've got both of them and have to say for a few times trying to tune a cb antenna for someone who don't get what SWR means, they can be intimidating.
    This morning I was reading about testing coax to determine losses and condition but in truth, you can't with an antenna analyser.
    Bout Z and rabbiporkchop Thank this.
  5. rabbiporkchop
    9,689
    6,541
    Feb 9, 2012
    Wapwallopen, Pa
    In the ADVANCED mode, the MFJ259B measures distance to fault. Not sure if the cheap ones do as well.
    I've never used that function before
    Blaskowitz Thanks this.
  6. Ridgeline
    22,706
    122,380
    That's a TDR which is software driven and pretty OK, but if you understand how to properly test coax for degradation, a TDR and even a loaded coax with a Antenna Analyser won't work. I find it odd that hams have been using an AA for testing and checking losses but it isn't accurate.
    rabbiporkchop Thanks this.
  7. rabbiporkchop
    9,689
    6,541
    Feb 9, 2012
    Wapwallopen, Pa
    Sure would be nice to have the money laying around for an Anritsu Sitemaster
  8. rabbiporkchop
    9,689
    6,541
    Feb 9, 2012
    Wapwallopen, Pa
    What do you think about this one?
    http://www.amazon.com/MFJ-226-Graph...tDescription_secondary_view_div_1457754567852
  9. Ridgeline
    22,706
    122,380
    I have something similar which suits my needs to a point. it is simple to operate for basic checking then getting into other things, it really isn't needed for cb band.
    I think my point is a simple device is best, if a good meter is found to be accurate, then a meter is easy to use.
    I have watched a bunch of videos on checking coax, continuity is a given and many make a big deal about using an ohm meter to find shorts but here is a very good way to check coax -
  10. Bout Z
    Bout Z Light Load Member
    275
    1,149
    Mar 14, 2015
    so. ohio
    What is your opinion of the sark analyzers? I've read mixed reviews online. Do they seem to be accurate? Most of the negative Ive seen, mostly refers to the build quality being poor.
    For one like myself, an analyzer would sit on the bench most of the time, which makes it hard to pull the trigger on a more expensive model (I was actually looking at the rig expert AA30) but for $100 bucks, and if it works like it should, I wouldnt feel near as bad about it lol.
    Would you recomend buying the sark, or throwing in the extra $ for a more expensive model?
  11. rabbiporkchop
    9,689
    6,541
    Feb 9, 2012
    Wapwallopen, Pa
    Looks like It calibrates easily
