Check engine light after fuel filter change
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mhlvc, May 16, 2020.
  1. mhlvc
    mhlvc Light Load Member
    111
    43
    May 2, 2020
    Peterbilt 579 2016
    Cummin ISX
    Changed oil and oil filter and everything was ok yesterday. Today I changed the fuel filter and water separator.
    First the truck didn’t want to start, then after a few tries - it started. Now it starts fine, but now I get a check engine light, doesn’t disappear.
    What could be the issue?
    -Didn’t tighten up the filters correctly?
    -Not enough fuel in the filters? (cant be since truck starts now?)
    -Sensors?
    Already tried the check engine reset when you turn the key to on and off 6 times but it didnt work.
  3. AModelCat
    164,449
    Is there a water in fuel sensor on the filter you didn't plug back in?
    BUMBACLADWAR Thanks this.
  4. Concorde
    Concorde Road Train Member
    5,469
    19,279
    Jun 29, 2016
    West Melbourne Florida
    It’ll go away, just give it a day or so.
  5. mhlvc
    111
    43
    May 2, 2020
    Don’t understand your question. I re-checked the 2 sensors on the water separator a few times, but maybe the wires came unplugged or something when I was changing the filter, not sure how to check
  6. mhlvc
    111
    43
    May 2, 2020
    I hope so, would hate to have it on all the time, even though I did everything correctly. Took it for a short drive, but still there
  7. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    More than likely "temporary code "from ,delay on "priming" and air in lines. Id turn it on and idle ,shut down several times.JMO
  8. Concorde
    5,469
    19,279
    Jun 29, 2016
    Happens to me once in awhile after I get a pm..Not every time. From low fuel pressure at the time you were getting it primed etc.
  9. mhlvc
    111
    43
    May 2, 2020
    Thanks for the replies, will see if it disappears the next few days.
    It was my first time changing fuel filters by myself so got scared I did something wrong, not a lot to it though
