Check points before buying
Discussion in 'Ask An Owner Operator' started by carwreck, Oct 2, 2011.
  1. carwreck
    carwreck Light Load Member
    155
    46
    Feb 11, 2010
    Chicago, IL
    Trying to learn and get more info on this.
    What are your checkpoints before you buy a used truck? what do you check for and how? I'm asking for more than just a pretrip. is it necessary to put it on a dyno? how much does that cost? pull ecm? oil sample?
    your help in this is appreciated!
  3. BigJohn54
    BigJohn54 Gone, but NEVER forgotten
    1,972
    1,599
    May 13, 2011
    SW Missouri
    I would have it checked by a mechanic unless you are very mechanically inclined. Do a dyno run, ecm print out and oil samples on the engine, transmission and differentials.
    I'd say about $400 for the dyno and oil samples.
    SHC Thanks this.
  4. carwreck
    155
    46
    Feb 11, 2010
    Chicago, IL
    how are these samples done? or do I let the mechanic do it?
  5. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    I would be real concerned if you found points to be checked on a diesel.
    On a more serious note.
    -Check all the rubber bushings in the suspension.
    -Check for air leaks.
    -Get some Arid Extra Dry. Spray it on all the places where oil typically leaks, fittings, steering parts, where the compressor mounts to engine, around compressor head and fittings, around base of water pump and hoses. It will not detract from the cleanup done on the engine. Just a slight white haze. Take it for a test drive of 10 miles. Now check those spots you sprayed. If you have even a tiny drop of oil leak the arid extra dry will react to it and give you a dark stain.
    -Check the frame for welds or repairs. Basically be the worst nightmare of a level one inspection that you have ever had.
    - Tire Depth If this truck is road legal you can say it is important. If it has poor tires, walk away.
    A dealer should be willing to work with you to guaranty your hapiness with the sale. Remember, it is your money.
    On a side note, I am hoping for work at Schneider. I will ask them if they will put me in a older truck that is going to be up forsale soon. That way I can drive it, if I like it after enough time I will buy it.
  6. carwreck
    155
    46
    Feb 11, 2010
    Chicago, IL
    your advices are much appreciated!
    roamer has it that schneider pays very well for owner ops if you wanna pull one of those ugly orange trailers. they sure have plenty of freight
  7. G/MAN
    G/MAN Road Train Member
    7,031
    8,625
    Sep 3, 2010
    You don't have to do a dyno, but it will give you a better picture of what is going on with the engine. A truck is a major investment in your future. The last thing you want is to spend all that money only to be surprised when it falls apart a couple of weeks after your purchase. Between the three checks, you should have a very good picture of the current condition of the primary components of the truck. All should be checked for a cost of between $200-400. But, these are not the only things you should check. You need to check suspension parts, bushings, kin pins, excessive or unusual wear on tires, etc., It would be worth paying a garage or mechanic to go over the truck with a fine tooth comb. You could skip all the checks and take your chances. You might get lucky. I prefer to spend the time and a few dollars to make sure that I am not going to need to start spending money the day after I buy the truck.
    SHC Thanks this.
  8. carwreck
    155
    46
    Feb 11, 2010
    Chicago, IL
    sounds like you've done this a couple of times.. will take the advice
  9. G/MAN
    7,031
    8,625
    Sep 3, 2010
    Yep, a few times.
  10. ShortBusKid
    ShortBusKid Heavy Load Member
    955
    1,269
    Dec 5, 2010
    Vegas
    I'd just add that even if you do all the checking, assume your gonna have some things break or that you missed that will need repair in the first month or two. I'd plan on having some extra cash sat aside for this. It is a used truck after all.
  11. G/MAN
    7,031
    8,625
    Sep 3, 2010
    Things can happen without notice. You could drop a lifter, lose an injector or blow a turbo. I have had all three happen, but not at the same time. The last turbo I had cost me about $2,500 installed. The turbo itself was over $1,500 exchange. The rest was labor and having the oil changed. I didn't want to take a chance of any metal particles getting into the bearings of the new turbo. I had one truck with a new rebuild that dropped a couple of lifters just after it got out of warranty. It cost me almost $7,000 ($6,700). A bad injector can cost about $800+ to repair. I think just the injectors cost over $400. The point is that things will happen, often without notice. That is why that those of us who have owned trucks for a number of years recommend that anyone considering buying a truck have several thousand dollars set aside for emergencies. I blew two tires on my last trip. I always keep at least one spare, but had to purchase one tire. I got lucky and found a small truck stop with a garage that sold me a decent used tire for $175 installed. It is unusual to blow more than one tire on the same trip, but it does happen. Even a used tire can cost over $200 plus the cost of putting it on the truck. New tires can run $400-600 if you buy on the road. In any business you need to plan for the worst that can happen. If you only plan for the best then you will not be prepared for something to happen.
    Big Don, alien4fish, carwreck and 2 others Thank this.
