checking disc brakes
Discussion in 'Experienced Truckers' Advice' started by snowwy, May 25, 2024.
  1. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    Anyone found a way yet?
    I bought an endoscope for my phone from walmart.com. But it comes with a Chinese app I'm not comfortable installing.
    Any suggestions on a endoscope or borescope or whatever. Or will that not work?
    expedite_it Thanks this.
  3. FLHT
    FLHT Road Train Member
    1,428
    2,544
    Aug 2, 2014
    Milwaukee has a battery powered borescope...
    Plumbers use them too.
    snowwy Thanks this.
  4. snowwy
    20,611
    13,326
    Jul 6, 2009
    That's a little pricey for something that will hardly get used.
    Amazon all comes with 16 feet cable. Plugs in to phone but that's too much cable.
    HF but the screen is small.
  5. wichris
    wichris Road Train Member
    4,479
    9,245
    Jan 17, 2011
    Just stick your hand in by the pads, you can feel the thickness of the pad. If they have dust covers, just take them off so you can see the wheel seals.
  6. Brandt
    Brandt Road Train Member
    4,622
    6,355
    Sep 17, 2012
    Looking for rust on the disc to make sure they are working properly is about all you check. Could look for cracks plus checking the pads. Probably have to pull tire off to check them
  7. Long FLD
    Long FLD Road Train Member
    12,835
    53,708
    Mar 4, 2015
    As long as the rotors are shiny I check my steer axle when I put tires on and I check my drives once a year when I rotate them.
    Suspect Zero and 86scotty Thank this.
  8. snowwy
    20,611
    13,326
    Jul 6, 2009
    I don't about you all but ain't no one getting hands anywhere on mine to feel the thickness. The caliper blocks the back and the bracket blocks the front.
    This is local traffic. Brakes don't last as long as long haul.
    I have to wait for a flat tire to see them.
  9. wichris
    4,479
    9,245
    Jan 17, 2011
    If I had one here in the shop I'd take a picture of my hand there. You feel with the tip of your finger.
    Been able to do it on FL/Volvo/Pete & all my trailers.
    cuzzin it Thanks this.
  10. 86scotty
    86scotty Road Train Member
    4,699
    12,896
    Aug 27, 2017
    Appalachia
    How many miles on truck or brakes? You'll be amazed at how long they last, local or OTR.
    I pull a wheel personally but I know that's not easy for some. You could drop by a tire shop and ask them to pull a wheel for you to check them out. Probably just cost you a few bucks since they aren't breaking down a tire.
  11. snowwy
    20,611
    13,326
    Jul 6, 2009
    655k.
    It had an inspection labor day week. And it needed brakes and rotors. But I didn't see any new rotors. And now the truck is starting to wobble with the brakes.
    Last time I had a flat tire right before the inspection. That tire was somewhat low.
