Cigarr lighter getting hot in an 07 Freightliner Columbia
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by gerardo1961, Jan 18, 2025.
  1. gerardo1961
    gerardo1961 Road Train Member
    1,750
    616
    Feb 21, 2010
    Miami
    Question,from time to time the cigarlighter in the cabin is hot and burning the plug in from my 12 volt arb fridge,nowbody can fixed the tell me go to the dealer what is the problem need help is a freightliner columbia 07
  3. AModelCat
    164,494
    My guess is that it draws too much power. A cigarette lighter socket isn't the greatest connection so if you're pulling a lot of amps through a less than optimal connection you're going to have heat produced.
    How many amps does it draw? You might be better off having the fridge wired up to a higher quality plug that can handle the amperage on a constant duty cycle.
  4. gerardo1961
    1,750
    616
    Feb 21, 2010
    Miami
    I not have clue you many amps,only i have this fridge 4 years like this never have a problem before wit a hot lighter
  5. FLHT
    FLHT Road Train Member
    1,428
    2,544
    Aug 2, 2014
    Faulty stuff like what you have causes a lot of truck fires.....
  6. 201
    201 Road Train Member
    12,756
    26,246
    Apr 16, 2014
    high plains colorado
    Este es caliente'! Bad ground. Electrical things that get hot in trucks is usually a bad ground somewhere,
    gerardo1961 Thanks this.
  7. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Your fridge is probably getting older and pulling more amps than it use too. @AModelCat is spot on. Replace your fridge and or hard wire it in for a better electrical circuit connection. The cig lighter connection is a temporary use device and not ment for continuous use. Replacement sockets are also available, but I would guess it’s gonna melt it again.
  8. Ridgeline
    22,717
    123,107
    Get a blue sea marine socket and plug, install that somewhere with direct wiring to a high amperage power source and fuse it at the power source, the lighter socket is limited to 5 amps continuous, the blue sea socket is rated at 15 amps,
  9. gerardo1961
    1,750
    616
    Feb 21, 2010
    Miami
    i am speak german,spanish and inglish i know my writting is bad , i speak better
    201 and dosgatos Thank this.
  10. gerardo1961
    1,750
    616
    Feb 21, 2010
    Miami
    i will looking for a blue sea socket in what place i can findet
  11. 86scotty
    86scotty Road Train Member
    4,699
    12,896
    Aug 27, 2017
    Appalachia
    Amazon or anywhere Google takes you. I'm a BlueSea fan but you can find cheaper options that work just as well, especially for a simple fridge connection. Just hardwire it to constant 12v power. Should be easy enough to find a source in your truck.
    A likely source is right behind the cigarette lighter socket that is getting hot. That is the bottleneck as Goodysnap said. Wire fridge directly from the wires behind the socket and make sure you have the right fuse in the fusebox for that socket (probably 15a).
    Your fridge should have an additional fuse on the side of it, make sure that is correct amperage as well.
