Class B - Automatic transmission
Discussion in 'Questions From New Drivers' started by jmnp, Sep 10, 2025.
  1. jmnp
    jmnp Bobtail Member
    4
    Sep 10, 2025
    New to the group. I had a question on the Class B parking brake test. Have a Class B truck with an automatic transmission. How do I test the parking brake without compounding the brake in order to shift from Neutral to Drive. Am I starting the truck, releasing the parking brake, then applying the foot brake in order to shift to drive, then pulling the parking brake with the truck in drive?
  3. TripleSix
    133,545
    Question: does the Class B vehicle have air brakes or hydraulic?
    If it has air brakes, the parking brake will be spring activated, and you pushing in the valve on the dash releases this spring. Will have nothing to do with the service brakes (the foot brake).
    If the brakes on the class B truck are hydraulic, the parking brake will be a set of brake drums while the service brakes will be disc brakes. . Even so, two completely different systems. The only thing the parking brake does is prevent the vehicle from rolling when parked. The major concern is service brakes. You should not be using the parking brake at all with the vehicle in motion.
    jmnp and OldeSkool Thank this.
  4. firemedic2816
    firemedic2816 Road Train Member
    1,147
    1,657
    May 14, 2016
    Walton Kentucky
    Chock your wheels throw it in neutral and get after it
    jmnp Thanks this.
  5. OldeSkool
    OldeSkool Road Train Member
    2,059
    6,594
    Jul 17, 2018
    New Hampshire
    This sounds like my mom’s minivan.
    WesternPlains, jmnp and Walk Among Us Thank this.
  6. Moosetek13
    Moosetek13 Road Train Member
    14,994
    19,059
    Nov 1, 2010
    Burnsville, MN
    How much foot brake pressure does it take to allow you to shift into drive?
    It is probably a switch on the brake pedal, so it would not be much. A quarter or half an inch?
    Barely anything for either air or hydraulic, so no compounding.
    I'm not familiar with that system, but I would think that setting the parking brake and then applying just enough pressure to the foot brake to allow you to shift into drive (then releasing the foot brake) would test it just fine.
    If you don't have a real teacher to guide you, maybe a little experimentation is in order?
    tscottme and jmnp Thank this.
  7. WesternPlains
    6,369
    57,425
    Sep 1, 2017
    Rapid City, SD
    :laughing-guffaw::laughing-guffaw::laughing-guffaw:
    Seriously....All Class B trucks are defective.
    You go to back one of those to a door.
    Looking in the mirrors.
    You turn the wheel.
    It goes the wrong way!
    Defective!
    Defective I tell ya!
    Defective!
    FredTheBasset, OldeSkool and jmnp Thank this.
