Hi all, I have been assigned a 2000 classic xl. Its a very nice truck, 3406 cat, 18 speed, 340,000 miles.... I love the truck but the ac blower seems to be pretty weak. On the high setting I have to put my hand about 6" away from the vent just to feel the air. I have checked and I am getting 4 speeds on the blower but they are all weak. I pulled the covers off the evaporator, the coils and blower wheel are clean. Any ideas? Thanks in advance
classic xl ac blower
Discussion in 'Freightliner Forum' started by southtx, May 24, 2011.
Filters?
A friend of mine didn't know that he even had inside filters, has owned the truck for like 5 years...pulled them out and they looked like a quilt. lol -
check to make sure the fan is going in right rotation--on a truck of that year--it has probabely be changed out a couple of times-- other than that--you pretty much have to pull the heater and evaporter cores out to see how bad they are--should be a little fiber filter in there as well
this is Century / columbia information unknown on classics. Yet there is a pre-air filter right by the main filter that is rectangular (2 clips) inside the engine compartment. Remove it for a test and see how your air blows. The problem with it out is that all the dirt that is outside now has a direct shot at the cab.
I used to think mine was clean by looking at the visible side of the heater core. You have to tear the dash apart and clean the hair/lint/fuzz from the windward side of the evaporator. That would be in between the htr and evap cores.
It will blow like a hurricane once its clean.
Same with the sleeper unit.
Then buy some of that cheap a/c filter media for window a/c and cut out a filter to fit where you need it. I put it on cab and bunk units. -
I just replaced mine for the same reason. In my classic it cost $78....
