Clogged Fuel Filter?
Discussion in 'Experienced Truckers' Advice' started by silverspur, Dec 24, 2022.
  1. silverspur
    silverspur Road Train Member
    1,756
    8,114
    Sep 26, 2012
    Minnesota sub zero temps, engine wouldn't start after sitting a few hours yesterday.
    Truck sat overnight in cold. Pushed it into garage and it thawed for five hours. Now it started without me doing anything to it and has been running for ten minutes.
    If this was you, would you be comfortable hauling freight to Georgia as is?
  3. Animosus
    Animosus Heavy Load Member
    732
    2,904
    Dec 7, 2015
    SE Wyoming
    I would change fuel filters for peace of mind.
  4. Espressolane
    18,649
    116,825
    Mostly. Would add a bottle of winter fuel additive to each tank, fashion a winter front for the grill with something that will withstand the road. Should get you down the road. Might not want to shut the engine down while in the very cold areas.
  5. Espressolane
    18,649
    116,825
    At least carry some new ones, just in case.
  6. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,012
    2,077
    Dec 15, 2021
    Don't shut it off until you get to Georgia.
    Buy some fuel in Minnesota, it should be winter grade.
  7. tscottme
    tscottme Road Train Member
    It sounds like ice in the fuel filter, no? Change the filters and drive toward the warm temps. I would not shut the truck off in sub-zero temps.
  8. Big Road Skateboard
    7,068
    40,045
    May 2, 2021
    Not clogged filters, just gelled fuel. Run it south
  9. Last Call
    Last Call Road Train Member
    7,568
    45,912
    Mar 15, 2021
    I would change the fuel filters reguardless cheap insurance
  10. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    Any time you gel up put new filters on. They cause a wax build up which isn't gonna go away.
  11. silverspur
    1,756
    8,114
    Sep 26, 2012
    Here's another question:
    2014 Intl. Prostar, not my regular truck
    Beep Beep Beep
    Water temp shoots up to 260, plenty of radiator fluid, no leaks. After a few minutes driving around yard comes back down to 140.
