closed tandems
Discussion in 'Flatbed Trucking Forum' started by yotaman, Mar 12, 2012.
  1. yotaman
    yotaman Light Load Member
    119
    57
    Jun 27, 2010
    MA
    Seems like everyones pullin a spread axle flat,and understandably so.But finding a good used one in my neck of the woods is tough right now,But there are a few closed tandem flats around for sale.So my question is, are these any good for running over the road.if not why?
  3. Mommas_money_maker
    Mommas_money_maker Road Train Member
    1,122
    765
    Oct 2, 2011
    North Carolina
    Sure if you constantly want to be checking and adjusting weight. If you run to Canada, they are perfect.
  4. Logan76
    Logan76 Crusty In Training
    4,528
    17,698
    Jul 12, 2009
    kittanning, PA
    we ran them sometimes on some old steel flats hauling oilfield stuff, the nice aluminum spreads got too beat up and they worked fine running local/regional because you did your best to guess where to place your load and then ran with it, most likely you weren't rolling across a scale and if you knew you couldn't go around one of the local scales easily you then made sure your weights were correct.
    yotaman Thanks this.
  5. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,163
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    The closed tandem trailers normally have a slider, so it isn't an issue in my experience.
    Just be sure that the tandems are on a slider, and are not fixed, and you will be just as good as a spread any day of the week but without the increased tire wear.
    Martin
  6. spacetrucker88
    spacetrucker88 Heavy Load Member
    i like the slow and paid for statement 10-4
  7. leftlanetruckin
    3,607
    3,163
    Mar 12, 2009
    Registered for 117,000lbs, and have a 460 Mercedes.....That IS slow:biggrin_2559:
    Paid for is a very good thing though!
    Martin
  8. Logan76
    4,528
    17,698
    Jul 12, 2009
    kittanning, PA
    Hey martin does your MBE have an exhaust brake instead of a jake? how well does that thing hold back when your at 117k?
  9. fortycalglock
    fortycalglock Road Train Member
    6,164
    6,613
    Jun 25, 2011
    Tourist Town, FL
    It depends on what you haul, how heavy, where you haul it etc. In FL, closed tandems are very popular since we can have up to 44,000 on them, no need for a spread. For OTR though spreads can be very beneficial in loading and scaling.
  10. leftlanetruckin
    3,607
    3,163
    Mar 12, 2009
    I have the Turbo Brake, not the Exhaust Brake. It was an upgrade when I ordered the rig new.
    It does OK to be honest, just have to run the engine fan as well as the turbo brake, and keep the revs up a little.
    I have heard the exhaust brake is like holding your hand out of the window though.....:biggrin_25512:
    Martin
    SHC Thanks this.
