Clutch fan problems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Tumbleweed88, Jan 21, 2022.
  1. Tumbleweed88
    Tumbleweed88 Bobtail Member
    Can someone please try to help me!! I am currently somewhere in BFE georgia and the clutch fan is not working. Its ab2018 Kenworth isx15. Is there any way to make it turn on and stay running until I can get it properly fixed?? Or does anyone have any tips, tricks or quick fixes?! any info is much needed and appreciated!!
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    Why do you need it to stay on are your temperature running high?
  4. bad-luck
    bad-luck Road Train Member
    3,417
    6,285
    Nov 16, 2013
    Baltimore, Maryland
    Not sure where it is located on your motor or if it work on a newer truck. But if you unplug the water temperature sensor, you will get a check engine light but your fan will run continuously. However this also depends on why the fan is not working.
  5. goga
    goga Heavy Load Member
    895
    1,586
    Nov 11, 2021
    Earth..
    Cut the air supply to it, see if it is staying engaged.
    Goodysnap Thanks this.
  6. Goodysnap
    Goodysnap Road Train Member
    3,767
    9,187
    Jul 12, 2017
    With no air to it if the blade still spins, it needs a clutch. No way to mechanically lock it.
  7. marmonman
    marmonman Road Train Member
    1,417
    2,843
    Dec 14, 2009
    central illinois
    If it is a horton fan clutch depending on which one you have you can lock it in with a bolt . Just Google it . A bendix is supposed to lock in when it loses air so I assume you have a Horton
