Clutch linkage replace question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Grainfarmer, Sep 26, 2018.
  1. Grainfarmer
    Grainfarmer Bobtail Member
    46
    8
    Apr 25, 2017
    Hey guys just was going to replace the buddy's clutch linkage arm on his 2006 379 with a eaton 18 speed and I came to a cross roads. I have the nut off rod that the linkage goes to and the nut off the bolt for the rod that goes to the paddle. So now I can't get the arm off the shaft thay goes into bell housing what am I doing wrong or have to do?
  3. AModelCat
    163,620
    Did you pull the bolt out of the lever on the transmission cross shaft? For some reason I want to say there might be a groove in the shaft for the pinch bolt.
    BoxCarKidd Thanks this.
  4. Grainfarmer
    46
    8
    Apr 25, 2017
    I'm not sure what you mean exactly. It seems to be there is also a thick spacer that goes between the nut and the lever it self.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,540
    6,616
    Aug 26, 2014
    Like he said the thick washer is holding it. Remove the bolt and washer. Then it should come off.
  6. pushbroom
    pushbroom Road Train Member
    1,787
    7,378
    Sep 1, 2012
    If you are just trying to get the aluminum arm off the shaft it can be a bit of a bear.
    Outside in goes nut, washer, steel stop collar, half moon key, aluminum arm.
    The steel collar seizes to the shaft and key and can be hard to remove.
    Key must be removed before the aluminum arm will come off
    SAR and spsauerland Thank this.
  7. WrenchWrenchWrench
    WrenchWrenchWrench Light Load Member
    131
    118
    Jan 3, 2016
    Those things can get stuck pretty bad, I've had to cut a couple off before.
