Clutch not working properly
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Stevekw, Feb 26, 2016.
  1. Stevekw
    Stevekw Bobtail Member
    21
    Feb 26, 2016
    I bought a 99 Kenworth w900 in December. It had around 15k on a new clutch. Last week while in reverse backing into a dock, I pressed the clutch to ease into dock and with pedal on the floor it was still pulling a little. Also after it did this the pedal had half its travel of free play. Couldn't find any linkage problem, adjusted clutch to 1 1/2" pedal free play. Now it acts dif every other time you use it. Going down the road the pedal will have very little free play. Get in some stop lights and it will go from little free play to 3 inches. Also occasionally with pedal on floor and in gear you can feel it pulling a little. Any ideas??
  3. AModelCat
    164,481
    Seen that happen once where the lever that attaches to the cross shaft was loose and slipping. The pinch bolt holding the lever to the cross shaft had loosend up and was gripping the shaft at different positions each time the pedal was pressed. You should see that lever on the LH side of the transmission bellhousing. Pretty easy to spot, its pretty big and the clutch linkage is attached to it.
    truckon, Stevekw and Straight Stacks Thank this.
  4. strollinruss
    strollinruss Road Train Member
    1,366
    1,699
    Jun 5, 2012
    Montgomery, TX
    Yup I think you are right on!
  5. Stevekw
    21
    Feb 26, 2016
    Makes sense to me. I'll check that when I get in tonight, thanks!
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Check for pieces of clutch damper springs in the bottom of the flywheel housing.
    lester Thanks this.
