clutch pedal
Discussion in 'Experienced Truckers' Advice' started by tkr2hrt, Apr 11, 2007.
  1. tkr2hrt
    tkr2hrt Bobtail Member
    24
    4
    Mar 27, 2007
    Victorville,California
    would please like to know is it diffucult to double clutch or there is another word for not using the clutch so often I think it's called powewr shifting I do believe
    which one is better of the 2 just asking to you pros out there
  3. mikroos5
    mikroos5 Medium Load Member
    357
    31
    Nov 16, 2006
    Mass.
    its called floating,and if done right its better for the transmission then double clutching.
  4. MNHillyBilly
    MNHillyBilly Light Load Member
    144
    9
    Feb 24, 2007
    I just saw an Eaton Fuller video that said the exact opposite......lol. Now I don't know what to think.
  5. mikroos5
    357
    31
    Nov 16, 2006
    Mass.
    well then i guess i have been doing it all wrong for the last 13 years.:biggrin_25526:
    dang i hate when im wrong.LOL:biggrin_2559: :biggrin_2559:
  6. MNHillyBilly
    144
    9
    Feb 24, 2007
    Yes, and now you know that..............lol
    With my straight truck I was only trained how to float. I sill don't have the double clutch down...to hard to upshift.
    Does DOT care either way when you go to test for a Class A?
  7. mikroos5
    357
    31
    Nov 16, 2006
    Mass.
    from what i hear you have to be able to double clutch,at least thats the way it is here.
    Dont know why to me its a preference thing not a for safety, TMO
  8. Matthews
    Matthews Medium Load Member
    315
    14
    Apr 5, 2007
    Akron,OH
    Floating is: no Clutch
    Double Clutching : is ( CLUTCH in gear ) *Clutch Out of Gear
    My opinion only, I FLOAT shift.... And in my eyes am saving my clutch lifetime.
    All the best, My 2 Cents,
    Matt
  9. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    Here's my 2¢. If you've been driving long enough you get to know the truck and what gear it needs to be in at any given speed. So you float the clutch because it's easy and you don't use the clutch so the the wear and tear is reduced. However, there are some that think floating makes you a better truck driver and I think that's bunk. The clutch is there for a reason and using it for each shift does not show you're inexperience it only shows your preference. Here's the problem I see with floating. A new driver (or some old)wants to float and once in awhile he will BANG a gear. I think that causes more damage than getting a few extra miles out of a clutch. The clutch is alot cheaper to fix than a busted tooth off one of the gears and the damage it will cause. So I think every driver should master double clutching before he/she even thinks about floating. And another problem with the clutch that some don't know. You don't need to put the pedal all the way to the floor for it to work. If you do that and the truck is rolling you'll bust out the clutch brake and you grind the gear at a stop trying to get it into the slot. At a stop you can push the clutch to the floor and select a gear without any grinding. If it does grind someone has blown the clutch brake.
  10. uncle bill
    uncle bill Bobtail Member
    40
    May 1, 2007
    Thats odd, I drove a fuller autoshift and all it does is float the gears for you!!!!
  11. MACK E-6
    50,019
    238,169
    I miss the days when the clutch brake was controlled by a button you mounted on the lever. I think we need to go back to that.
