Clutch Replacement
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dazed&Confused, Jan 10, 2015.
  1. Dazed&Confused
    Dazed&Confused Bobtail Member
    43
    16
    Nov 1, 2014
    Can the Eaton Easy Pedal clutch replace the clutch in a Rockwell 10 Speed? Current clutch has a really hard spring in it. Only use it to get moving and float the rest, but sitting at a light for any amount of time you most definitely sit in neutral.
    Any idea of pricing on one?
  3. richardj87
    richardj87 Bobtail Member
    31
    9
    Aug 24, 2013
    dsm Iowa
    I am sure Eaton makes a clutch for your application pricing varies depending upon engine the clutch is behind torque rating of the engine wither you are wanting a new or reman clutch. we usually pay $450-$800 for the clutches we use
    I personally am a fan of the Sachs twin xtend clutch self adjusting clutch win a manual override
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,539
    6,612
    Aug 26, 2014
    It can, along with the correct torque also be sure the clutch hub is not to big for the flywheel recess. If your truck has a single disc (17"?) you will be replacing it with a double disc (15.5"?). The only problem is that some flywheels are not drilled with both bolt patterns and requires machine shop labor. If you can buy a new clutch without a core charge it may be less expensive than a reman. I have bought some salvage yard cores for $50 to save money. If you go with a reman I suggest you get some local references from people using them not selling them.
  5. mbx1
    mbx1 Bobtail Member
    Santa Barbara California
    in my experience always a new eaton clutch, get the biggest one that fits your flywheel recess and it should last and last
  6. BoxCarKidd
    4,539
    6,612
    Aug 26, 2014
    Cables and hydrolics can also cause high pedal pressure
  7. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,734
    Jan 30, 2010
    keep stroking.
    I prefer a lipe clutch over an eaton.
