Clutch
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mr Bob, Oct 26, 2023.
  1. Mr Bob
    Mr Bob Light Load Member
    269
    84
    Mar 17, 2015
    typical 2 disc pull clutch. wont go in gear with engine running. Clutch brake is intact. engine off in gear, start engine with clutch pressed half way. release clutch and it acts normal. press clutch down to clutch brake and truck moves forward as if clutch is being released. what the heck is going on?
  3. jamespmack
    216,471
    Do you have a 1/4" between release fingers and bearing? Have you tried rotating clutch brake by hand, to check if the tangs are broken off?
    Oxbow and Big Road Skateboard Thank this.
  4. jamespmack
    216,471
    Also I apologize, I'm trying to understand what your describing.
  5. Mr Bob
    269
    84
    Mar 17, 2015
    tangs are there. i know this sounds real goofy. ive never seen it before.
    jamespmack Thanks this.
  6. JB7
    JB7 Road Train Member
    1,001
    1,770
    Dec 13, 2022
    Laurel, MD
    "wont go in gear with engine running" Clutch is not fully releasing. May be a weak pressure plate, broken springs, a sticking intermediate plate. If adjusted properly then the trans needs to come out to inspect and replace the clutch. First check the cable or linkage. Also, with the bottom plate off have someone press in on the clutch and look to see if the bearing is contacting the clutch brake.
  7. Diesel Dave
    9,599
    32,199
    Jan 20, 2010
    Hesperia, Ca.
    Sounds like those “Self-adjusting” clutches. I threw mine away when I had the transmission gone thru.
    Last Call and Oxbow Thank this.
  8. Mr Bob
    269
    84
    Mar 17, 2015
    manual adjust
    Diesel Dave Thanks this.
  9. Big Road Skateboard
    7,057
    39,968
    May 2, 2021
    How about a pic @Mr Bob, from the inspection plate looking up towards the throw out bearing?
    Oxbow and Diesel Dave Thank this.
  10. jamespmack
    216,471
    Damper springs broken and stuck between clutch discs
  11. jamespmack
    216,471
    Put your fingers down in bottom of housing in the crud. Probably gonna find some pieces.
    Oxbow Thanks this.
