C'Mon man
Discussion in 'Freight Broker Forum' started by JonJon78, Feb 26, 2021.
  1. JonJon78
    JonJon78 Road Train Member
    7,240
    43,006
    Jul 1, 2018
    Was headed towards my pickup this morning and my trusty broker calls wanting ETA because her customer wants to get everything ready for my arrival... Sounds great.
    I tell her I'm 30 minutes away, fantastic was her reply.
    5 minutes later she calls back to inform me the load is canceled!!! SMH:biggrin_25512:
  3. Doealex
    Doealex Medium Load Member
    597
    1,132
    Feb 21, 2018
    If it's any consolation to your problem, those 5 minutes could've lead to bigger problems (accident, etc.). You got off easy this time;););)
  4. PPLC
    PPLC Road Train Member
    1,946
    6,294
    Jun 15, 2017
    St. Paul, MN
    Oof. Sorry dude. That stuff sucks.
    Rideandrepair, D.Tibbitt and JonJon78 Thank this.
  5. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    I hope there going to pay for a TONU?
    If your going that way and feel like it, stop by the shipper and say "I'm here to pick up xyz123 going to wherever" and see what kind of answer they give you.
    Mattflat362, Lite bug, Tug Toy and 9 others Thank this.
  6. 6wheeler
    2,696
    4,774
    Aug 30, 2009
    Just guessing at this so take it with a grain of salt.
    The shipper didn't "cancel" that load. An order for a tractor trailer just doesn't get "cancelled".
    What the receiver decided they didn't need a tractor trailer load of inventory? And if something else happened like production or mechanical failure the broker would have been happy to explain the problem instead of saying it's "cancelled"
    Translation, someone else got that load.
  7. PPLC
    1,946
    6,294
    Jun 15, 2017
    St. Paul, MN
    Depends. I run into actual cancellations or postponements from time to time. It's usually a matter of a job getting cancelled, or a jobsite getting shut down, or my customer's customer deciding to cancel the order for timeline reasons, or so on. I can't actually speculate as to what happened in @JonJon78's case, but those are the most common reasons that happen on my end.
  8. 6wheeler
    2,696
    4,774
    Aug 30, 2009
    Sure. That does happen. But an explanation from what I have read wasn't given, just that it "cancelled".
    I showed up about 5 years ago at a chemical plywood treatment plant after the broker called and said it was cancelled. Guess what, I picked up the load and called the broker back and said, there must have been a mistake. This load is good, I got it and it's on the way.
  9. PPLC
    1,946
    6,294
    Jun 15, 2017
    St. Paul, MN
    Certainly, and situations like yours happen as well. Just pointing out that it could actually have been a cancellation. That's all.
  10. p608
    p608 Road Train Member
    2,181
    2,993
    Nov 10, 2016
    Sometimes the receivers credit doesn't go through
    Rideandrepair Thanks this.
  11. Pepper24
    Pepper24 Road Train Member
    2,098
    1,640
    Dec 3, 2010
    You must work with really crappy brokers for it to always be some under handed terrible seedy people wit no scruples or ethics it’s probably your service failures you have from just leaving loads you have with so many companies that you have to work with people with the low business ethics you have to work for.The OP didn’t give a lot of information for you to say the broker didn’t give I don’t know if that’s true or not but believe it or not loads do cancel for many reasons.
    JimmyTwoTimes, Rideandrepair and p608 Thank this.
