Cobra 148GTL-ST Issues
Discussion in 'CB Radio Forum' started by Kickstand-117, Jul 12, 2014.
  1. Kickstand-117
    Kickstand-117 Light Load Member
    126
    60
    May 22, 2014
    Asheboro, NC
    I have a Cobra 148GTL with sound tracker, and I run an OLD RK56 on it. I took it out of my old truck and put it in my big metal boat of a Crown Vic. I put a decent magnet mounted antenna on it, running RG8X coax. After checking my SWR and adjusting my whip length, I have a 1.2 across all channels. Then, I come out a few weeks later after the install and go to start yappin' away, but when I key the radio makes a whining sound. It's fine when I'm not transmitting, but as soon as I key, it makes this noise. Any ideas on what it could be?
  3. Ridgeline
    22,719
    123,182
    Did you try a stock mic?
  4. purpleprime
    purpleprime Medium Load Member
    681
    720
    May 30, 2013
    spickard, mo
    Do you have a good ground to the radio bad grounds always cause issues and how do you have it powered CIG lighter or did you run wires?
  5. Kickstand-117
    126
    60
    May 22, 2014
    Asheboro, NC
    I haven't yet. I have a good 4 or 5 radios, but all have different mic plugs. You think it could be the mic? I'll ride out to a buddy's and see if he has a Cobra 4 pin mic I can check with.
  6. Kickstand-117
    126
    60
    May 22, 2014
    Asheboro, NC
    I have it run through my stereo fuse in my fuse panel, and ground going to a screw in my door frame. It's a 91 Crown Vic so there's plenty of metal.
  7. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    Wire it straight to the battery with some 10 gauge wire. Be sure and put a fuse out there by the battery too. I don't know if that will solve your problem, but that is the correct way to power a radio.
  8. Taildragon
    Taildragon Heavy Load Member
    723
    449
    Jun 22, 2012
    Indiana
    Every time I had that happen it was a mic cord problem, torn ground lacing, soldered wire connection broken loose, or broken wire, that type of thing.
  9. Ridgeline
    22,719
    123,182
    That's what I'm thinking, the mic cord has a broken wire, the best thing to try is another mic.
  10. Kickstand-117
    126
    60
    May 22, 2014
    Asheboro, NC
    I am more than happy to hear that. I'd much rather get my mic rewired than have to fix my radio. I'll go hunt down a mic later today.
  11. Kickstand-117
    126
    60
    May 22, 2014
    Asheboro, NC
    That's how it was powered before, I just don't have enough wire to run it to the battery. It'll probably be wired with 8 gauge because what I use with my amp. Shouldn't be a problem, should it?
