cobra 29 classic, whats wrong?
Discussion in 'CB Radio Forum' started by Boomer 1, Apr 25, 2013.
  1. Boomer 1
    Boomer 1 Medium Load Member
    421
    137
    Oct 26, 2011
    Central, NC
    When I key the mic I can talk and others here but when I let off the tx and ant light stay lit... I have to either key the mic a few times or shake the radio gently then I can here others. Has to be bad mic,right? Antennas are good.
  3. vintech
    vintech Light Load Member
    89
    62
    May 30, 2010
    Well It certainly could be the mic..and you would want to make sure it's not the mic before you go on to something else.. Try to find someone that has a cobra 29 LTD any version of the 29 Cobra will work just to make sure use there mic in yours and yours in there's maybe that will let you know..
  4. cuzzin it
    cuzzin it Road Train Member
    3,641
    12,423
    Jan 19, 2008
    Berea, KY
    You have to shake the radio to receive ?
  5. JIMROY
    JIMROY Medium Load Member
    424
    331
    Feb 15, 2013
    ESCONDIDO CALIFORNIA
  6. #1 Kenworth
    #1 Kenworth Light Load Member
    105
    91
    Sep 21, 2012
    New England
    My guy found the mic pins on the radio end loose causing issues. Gently pried the pins a but bigger for a tighter fit. All good.
    JIMROY Thanks this.
  7. Boomer 1
    421
    137
    Oct 26, 2011
    Central, NC
    Thanks everyone!!, I ordered a RK 56, will be at the house tomorrow.
    Cuzzin yes either key the mic or shake, mess with, turn off back on, anything that gets it back to normal. Its been very intermintent lately, hopefully the mic works or I'll try #1 Kenworth advice.
    Again thanks ya'll
  8. Child of God
    Child of God Light Load Member
    108
    68
    Mar 18, 2013
    Coeburn VA
    Sounds to me like the radio needs a good cleaning of all parts inside and out, mike included.
  9. Everett
    Everett Crusty Shorts, What???
    2,095
    6,401
    Oct 20, 2009
    Hampton,Ia
    they still use a cb bought a new one hardly nobody on it to use it, to talk to anybody
  10. EZ Money
    EZ Money Road Train Member
    If you were using an old RK-56 the new one will not sound as good......they got bought out and Turner no longer makes them.
    It will still be an improvement over the stock mic.
    If you have the old 56 and it says Turner Telex on the back DO NOT get rid of it.Have it repaired.
    It is usually the spring inside breaks on the older mics.
    The best mic on the market now is the Ranger SRA 198...
    I have a new RK-56 and a new Astatic.....both ended up in a drawer in my sleeper.The Ranger sounds way better!
    darthanubis, Everett and Boomer 1 Thank this.
  11. Boomer 1
    421
    137
    Oct 26, 2011
    Central, NC
    Hooked up the Mic, thought all was good...WRONG... tryed to calibrate now same thing happening AND the swr's are way high? I hope this is operater error, but I don't think so?
