Cobra 29 help
Discussion in 'CB Radio Forum' started by earthmover, Dec 17, 2015.
  1. earthmover
    earthmover Medium Load Member
    563
    20
    Jan 27, 2009
    castalia , north carolina
    Ok guys my cbs makes a loud noise when I key the mic if it close to the cbs move away from the cbs noise goes away. .could this be a ground problem. .or what do I need to look for..others can hear me talk as long as the mic gain is down which the noise is not there turn gain up mic close noise is the..
  3. PaganDevil
    PaganDevil Light Load Member
    78
    51
    Oct 2, 2015
    Sound like feedback turn off talk back if you have it. Run a good noise canceling mic keep the mic gain turned down. Don't hold the mic close to the radio.
    Bout Z Thanks this.
  4. rabbiporkchop
    9,689
    6,543
    Feb 9, 2012
    Wapwallopen, Pa
    I've never seen that happen on a stock radio unless the microphone was damaged or had loose wires inside the plug. It only seems to happen on radios that have been tampered with by people who aren't qualified to change a lightbulb. Is the radio stock unmodified? Are you the original owner of this radio? Has anyone been inside this radio? Again this is not something that normally happens on a properly aligned radio. Once the automatic modulation control circuit has been hacked up or disabled this is when you start to have problems like this.
    Reason for edit: microphone maintenance
  5. earthmover
    563
    20
    Jan 27, 2009
    Not it's been worked on ..I got it from the radio shop outside sulfur va...but it worked fine before ...I guess I'll have to take it in to the local shop to be checked out
    rabbiporkchop Thanks this.
  6. rabbiporkchop
    9,689
    6,543
    Feb 9, 2012
    Wapwallopen, Pa
    It would be worth trying a different microphone to see if the problem replicates itself with a different microphone
    Bout Z Thanks this.
  7. Bout Z
    Bout Z Light Load Member
    275
    1,149
    Mar 14, 2015
    so. ohio
    Yupp..try a noise cancelling mic first, if you havent already. Dont turn the mic gain to high...
  8. burnsey
    burnsey Light Load Member
    81
    40
    Jan 24, 2014
    seacoast, NH
    Shorted RX/TX wire in the mic pin will do exactly that. Swap mics and give it a try, it'll probabably fix it.
    EZ Money and rabbiporkchop Thank this.
  9. earthmover
    563
    20
    Jan 27, 2009
    OK thanks guys
  10. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Everybody beat me to it but i was gonna say either mic issue or speaker feedback..
    As for mic gain,once.repaired you should ne able to run mic gain wide open..Most likely about 3/4 will sound best..Again that depends on whats been done..
  11. earthmover
    563
    20
    Jan 27, 2009
